Edelbrocks new Pro Flo XT intake
Old Sep 8, 2008 | 12:23 PM
QuickGlass's Avatar
QuickGlass
Default Edelbrocks new Pro Flo XT intake
Does anyone know if Edelbrocks new Pro Flo XT intake will fit under Corvette hood?
http://www.edelbrock.com/automotive_...xt_chevy.shtml
Old Sep 8, 2008 | 02:38 PM
tequilaboy's Avatar
tequilaboy
With a height of 9.09" above the china wall it looks like it may work. The throttle body may be an issue. Somebody needs to spend $415 and try it out.
Old Sep 8, 2008 | 02:53 PM
Bad Karma's Avatar
Bad Karma
It'll be more than that, need throttle body, probably throttle cable, small cap distributor, fuel rails, regulator, etc.
adi4's Avatar
adi4
Old Sep 8, 2008 | 04:38 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I would like to know if it fits and what is needed also. Do you think it can run with a C4 ECU like a super ram or mini ram, or do you need the whole kit??
Old Sep 8, 2008 | 05:18 PM
Orr89rocz's Avatar
Orr89rocz
you could run it on L98 ecm's. just use LS1 TB and the appropriate LS1 IAC and TPS sensors and wire them into your stock wiring. They use the same voltage signals as the L98 cars.
I am not sure of the injectors but they do look to use the universal GM/FORD style that we have
So the swap is easy. Just need fuel lines to the rails and swap those sensors.
it looks shorter than the HSR from the pics so that may be a good indication of its height. How much smaller/shorter than the HSR does the intake have to be to fit?
Old Sep 8, 2008 | 09:23 PM
86C4CONVERTIBLE4+3's Avatar
86C4CONVERTIBLE4+3
Default that easy?
You make it sound almost too easy. If it really is, this may just be what the doctor ordered for my 86 over the winter. If someone puts one of thes on an L98 please post how it all worked out and what was required. Gotta be something over on TGO on this too I would think.
Old Sep 8, 2008 | 11:07 PM
Orr89rocz's Avatar
Orr89rocz
yep there are two threads talking about it, one with more information than the other but basically it sounds like all you need is LSx TB, LSx TPS/IAC connectors to splice into your TPI harness, and custom fuel lines
thats it
Old Sep 8, 2008 | 11:43 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Someone on here measured 9.150" max on the front china wall.
It may just work, does somebody have a link to where you can buy just the intake, not all the other stuff in the package.
I've seen the threads discussing it, not seen many... any running it...
EDIT: I see the release date got pushed back again...that would explain it.
Old Sep 8, 2008 | 11:50 PM
Corvette Chris's Avatar
Corvette Chris
I'm another one interested in hearing if this fits...
Old Sep 9, 2008 | 12:16 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Is this the intake that the R/D guy from Edelbrock was talking about. I remember he was here and on 3rd gen talking about the new manifold they (he) was designing. I remember he said it would fit under the hood of a C4 Corvette. Total cost was supposed to be $400.00. They came pretty close, looks like about $550.00 plus TB and electronics.
Old Sep 9, 2008 | 12:29 AM
Corvette Chris
I don't remember a guy from Edelbrock. I do remember a guy from BBK, that ring a bell?
Old Sep 9, 2008 | 12:30 AM
Firevette's Avatar
Firevette
Cruise-In X Veteran
I think your talking about the guy from BBK. Thay also have one in the works.....it will be out in a few months...
Old Sep 9, 2008 | 12:35 AM
Firevette's Avatar
Firevette
Cruise-In X Veteran
You beat me to it!
I have a small cap dizzy sitting in the garage somewhere......
I think i'll have to go outside with the measuring tape tomorrrow.
Old Sep 9, 2008 | 12:38 AM
Corvette Chris
Originally Posted by Firevette
You beat me to it!
I just checked BBKs website over the weekend. Winter '08 release.
I'll be interested to hear your measurements. I've gotta believe that the 9 inches is close to the height of a TPI setup.
Old Sep 9, 2008 | 12:41 AM
Corvette Chris
OK, so I was curious.
Went out to the garage, and a rough measurement looks like the height is 8 3/4-9". Can't tell for sure, too many things in the way.
Old Sep 9, 2008 | 12:47 AM
Demonic85's Avatar
Demonic85
So is this comparable to a Holley Stealth Ram or more like a mini-ram?
To Edelbrocks new Pro Flo XT intake
Old Sep 9, 2008 | 12:54 AM
RandyJ75's Avatar
RandyJ75
http://www.thirdgen.org/techboard/tp...e-setup-6.html
Orginal post over on third gen
Old Sep 9, 2008 | 09:44 AM
TA's Avatar
TA
Thats the thread about the BBK turtle-ram, not the Edelbrock
Old Sep 9, 2008 | 10:59 AM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Originally Posted by TA
BBK turtle-ram
