Need VATS (no-start) help
Old Sep 8, 2008 | 04:59 PM
cuts's Avatar
cuts
Cruising
Default Need VATS (no-start) help
My 1993 will sometimes not start (always starts after sitting overnite)--the engine will fire & run about 1-2 seconds & then die--will do this for 10 to 15 tries before it actually starts--runs fine after that--never a miss or anything--noticed that sometimes while driving that the security light & the SYS light will flash 3 times every 15 seconds--they sometimes will stop flashing while driving & then start up again--i think they are related to my no-start problem, but my mechanic can't figure it out--anyone had this problem & how was fixed? Would really love to stop at the store for beer & know the car will start when time to leave. Thanks
Old Sep 8, 2008 | 05:18 PM
pmihaltian's Avatar
pmihaltian
Slingshot
What CODES is the OBD throwing?
Old Sep 8, 2008 | 05:38 PM
cuts's Avatar
cuts
Cruising
OBD ? (same as the CCM ?)Got following codes from the CCM---B0041 & B0054 & B0072 & B0074
Old Sep 8, 2008 | 05:43 PM
MK 82's Avatar
MK 82
if it cranks its not vats!!
Old Sep 8, 2008 | 08:57 PM
engle1147's Avatar
engle1147
I agree if the car cranks and you have injector pulses you don't have a Vats issue.
Get a hold of a fuel pressure gage and do a fuel system check first. Check for proper pressure and bleed down times. If the fuel system check produces no problems or issues you may then want to ohm out the fuel injector coils too.
Good Luck!
To Need VATS (no-start) help
