interior light problems
Old Sep 8, 2008 | 09:29 PM
bobs94's Avatar
bobs94
1st Gear
Default interior light problems
my dad has a 92 lt1 and his interior lights stay on and kill his battery we believe its a bad ground and where are the grounds for those lights
Old Sep 8, 2008 | 10:36 PM
engle1147's Avatar
engle1147
I don't have a FSM for a '92....my best guess ....the door jam switches are stuck or the BCM (body control module) might have issues.... I'm sure someone will post eventually....hang in there.
Welcome to the Forum!
Old Sep 8, 2008 | 11:12 PM
garychurchill's Avatar
garychurchill
I have the same problem. Still haven't figured it out, so I have the fuse pulled. Mine's a 95 btw.
Old Feb 24, 2009 | 11:13 PM
Batyrkhan's Avatar
Batyrkhan
Mine is 95 copue. Same problem. Yesterday I have tried to locate f..ng delay timer, as its stated from one thread it should be under dash near ECM, no luck. I guess its beacuse I have 95 model and could be somewhere else.
PLease let me know if you find solution.
Batyr
Old Feb 25, 2009 | 08:40 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Originally Posted by engle1147
I don't have a FSM for a '92....my best guess ....the door jam switches are stuck...
Very common issue. Also check the rear hatch switch too. I had the exact same issues, at different times, with both of these.
Good luck.
Old Feb 27, 2009 | 03:00 PM
garychurchill
I fixed mine!!!!!!
It was the passenger door switch! The switch must of been malfunctioning. I just HAPPENED upon it, because I had the car parked for about 3 weeks and decided to plug back in the fuse and try to find the problem. To my astonishment they all turned off when I closed the door! Then about a minute or 2 later came back on, so I knew it had to be that door.
I ended up spraying down the switch with silicone and now it works fine!!!
To interior light problems
