won't start 1990
Old Sep 9, 2008 | 11:55 PM
gvrabac's Avatar
gvrabac
Default won't start 1990
hey guys,
help me out, I don't have any more ideas and I am a little nervous to start playing around with the VATS system. Here's what happened. I was working on the exhaust and had to remove the exhaust manifold on the passenger side. it was the only thing i could do to remove the starter. here's were I screwed things up. Instead of properly removing the wires I let the starter hang by them. not realizing that the stud with the purple wire to the solenoid was touching the case, i put everything back and went to start the car. and.......nothing. So my question is would this have anything to do with VATS. everything was working fine before this and I had the starter serviced and checked. Oh ya, its a 1990, automatic.
Old Sep 10, 2008 | 12:20 AM
engle1147's Avatar
engle1147
VATS may or may not be the issue. The VATs only closes the relay for the starter to start....it is not inline with the starter in any way....shorting the starter out to a ground should not have caused a problem with the system. VATS also enables the fuel injectors pulses to the ECM. The signal that enables the 2 processes to happen is triggered by the resistance in the your key pellet.
Is your car doing anything at all when you turn the key to crank it?
Does the dash come on...lights..ect?
Check to see if you have injector pulses.
Old Sep 10, 2008 | 01:52 AM
rodj's Avatar
rodj
Purple is hot wire to starter , only live when you turn to the start position.
Old Sep 10, 2008 | 09:31 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If it does not crank, check for clean and tight connections and battery and starter.
Put a test light or meter on the stud with purple wire, have someone turn the ign to start position. If no power is at solenoid during crank, trace the circuit backwards to shifter select switch and starter enable relay.
My schematics are for an 86, but should still be of some use.
http://members.shaw.ca/agent86/Start...g%20System.pdf
Old Sep 10, 2008 | 03:25 PM
gvrabac's Avatar
gvrabac
there is no power to the purple wire in the on position, and yes i have all my lights working, in and out. Is there any other locations for fusing besides the passenger side panel by the door?
Old Sep 10, 2008 | 03:30 PM
gvrabac's Avatar
gvrabac
also there is a relay under the drivers side kick panel with the yellow wires going to it, I am assuming it is the starter relay. It opens and closes with the turn of the key, and all the wires exsept the black/yellow.
Old Sep 10, 2008 | 03:39 PM
MK 82's Avatar
MK 82
There is only 12V to the purple wire with the key in the start position. This closes the starter relay.
Grounding this wire to the eng will do nothing electrically with the key off. The large GA wire however goes straight to the batt and is always hot. Used to jump them with a screwdriver.
Old Sep 10, 2008 | 07:19 PM
gvrabac's Avatar
gvrabac
here's a dump question, just to be clear. which wire goes where on the starter? i'm not sure if i possible mixed things up.
Old Sep 10, 2008 | 10:06 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
hey guys,
Was the battery disconnected when you did this? Was there a spark or noise?
If the battery was still connected, you may have blown a fuseable link.
Old Sep 10, 2008 | 10:34 PM
gvrabac's Avatar
gvrabac
where would i find this fusible link
Old Sep 10, 2008 | 10:52 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default fusible link
Some of the fusible links are behind the battery,
Some are on the red battery small wire coming out of the big wire Positive cable on the battery.
Behind the battery, there is a terminal connector with some red wires bolted to it. Does that have power with the battery hooked up?
Old Sep 10, 2008 | 10:58 PM
RandyJ75's Avatar
RandyJ75
They are behind the battery, take a look and see if any look "burnt".
Old Sep 10, 2008 | 11:47 PM
gvrabac's Avatar
gvrabac
here's an intresting question for you guys. If I wanted to bypass this issue for the time being, so i can enjoy the last little bit of warm weather. would it do any harm if i were to install a push button start. I have already ran the wiring and it seems to work fine. just like jumping it underneath. is this ok????
Old Sep 11, 2008 | 01:23 AM
RandyJ75's Avatar
RandyJ75
I wouldn't do it, but it's your car. Screw it up all you want.
Old Sep 11, 2008 | 08:26 AM
AGENT 86's Avatar
AGENT 86
Does the car run after being cranked, using your bypass ??
Why not trace the circuit back, fix the problem, and then enjoy the last of the warm weather.
Old Sep 11, 2008 | 11:49 AM
gvrabac's Avatar
gvrabac
just noticed something. not sure if it helps. I tried the bypass and it works ok, and it will get me through the rest of the summer. but i noticed that i can change the gears in the car without pushing the brake, and i can also start the car in gear. all with the key in the on postion.
Old Sep 11, 2008 | 08:11 PM
Vetster88's Avatar
Vetster88
Originally Posted by RandyJ75
fusible link.
What could have happened was not a blown link, but a broken link or internal wire.
Rule #2 about R&R a starter... NEVER let it hang by the wires! the only wire that can handle the load is the primary 12v wire from the battery.
What can happen when starter hangs is the wires inside the protective coating can pull a part especially with a fusible link. you'll be able to feel 'em if they're burnt, and if your good you'll be able to feel 'em if they are broke
My bets are on the fusible links.
Old Sep 11, 2008 | 09:41 PM
gvrabac's Avatar
gvrabac
i have tested them once, but a second time won't hurt.
To won't start 1990
