Which Diagnostic Software
Old Sep 14, 2008 | 04:30 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Which Diagnostic Software
OK, I'm looking at Datamaster and if I understand their website correctly they require a serial port DB9 connection.
The cable I purchased is USB. Can Datamaster use USB, do I have it wrong?
If not Datamaster, here's a link of other software. Which one do you guys use that will support an USB based cable?
None of my laptops have DB9 RS232 connectivity.
http://www.aldlcable.com/sc/pages.asp?pageid=20
Thanks.
Old Sep 14, 2008 | 05:07 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
The Datamaster software will generally work when you use a Belkin F5U103 or FTDI US232B adapter. Not all USB adapters are created equal but the Belkins seem to be the most reliable and usable.
Old Sep 14, 2008 | 05:17 PM
jsup's Avatar
jsup
I have that, the cable I have us USB to OBD1 connector. My laptop has no Serial Com Port. (DB9 RS232)
Old Sep 14, 2008 | 05:24 PM
engle1147's Avatar
engle1147
This might work for you:
http://www.cablestogo.com/product.as...=116&sku=26886
Old Sep 14, 2008 | 05:32 PM
jsup's Avatar
jsup
Thanks guys...the physical connection isn't the problem
The issue is the software may or may not have drivers that support USB.
Again, the cable goes directly to the OBDI connector, and connects to my laptop USB. There is no physical interface problem.
I am wondering if Datamaster has the drivers for USB, will it recognize a USB cable? If I am plugged in PHYSICALLY will it work LOGICALLY?
Their site is unclear on the issue.
I can't tell from their website.
Old Sep 14, 2008 | 05:45 PM
mseven's Avatar
mseven
it will recognize a usb, first dedicate a comm port, and 'enable handshake' in the program (quicker communication is good), and you might need a resistor in the cable.
Old Sep 14, 2008 | 05:46 PM
jsup's Avatar
jsup
I have a selectable cable. It has a jumper for resistor or not. I believe I do need a resistor, at least I knew when I ordered it a while back. How would I know for sure? Can I damage it if I connect it with or without a resistor and it does not need one?
Old Sep 14, 2008 | 05:48 PM
engle1147's Avatar
engle1147
Note 1.4.3 of :http://www.ttspowersystems.com/softw...cs/DM32MAN.PDF
Using window 98 or older ......says yes- it will work but most USB serial are not compatible with the ALDL baud rate
Old Sep 14, 2008 | 05:53 PM
jsup's Avatar
jsup
Yes, that assumes your cable from the OBD1 connector is DB9. I don't have that. My connector is straight USB.
Mine cable is like this:
Old Sep 14, 2008 | 05:56 PM
engle1147's Avatar
engle1147
I got you on the cable thing......it should work then.
mseven's Avatar
mseven
you will know, if the fans will come on w/key on the 'on' position, this will mean try a different position. Try middle position first, should not damage anything. Other 2 positions will either recognize the comm port or not. Before you start the car, key on the 'on' position NOT START or RUN, pull record data window down, set to monitor and record off, you will see alll data w/out running, if not try other position.
Once you are there, you can record /monitor. Make sure screen saver timer at least 40 min. along w/all other power options (hard drive etc.) when running on battery to at least 40 min, this will give you max. record time.
Old Sep 14, 2008 | 07:16 PM
Aurora40's Avatar
Aurora40
FWIW, Datamaster is free to try. So try it.
I use it with a USB adapter. There's a check box on one of the Datamaster menus for using USB. I don't recall offhand where exactly.
Old Sep 14, 2008 | 09:54 PM
convas's Avatar
convas
It should work fine with your cable, most of the problems come when you use a serial to USB converter which you are not.
Old Sep 14, 2008 | 11:22 PM
rodj's Avatar
rodj
John ,
have you installed the USB to serial adapter software that lets the laptop see the USB cable?
Check ouit http://www.ftdichip.com/FTDrivers.htm
If you have no luck, PM me your address and I will email you the file
Old Sep 15, 2008 | 12:52 AM
Zix's Avatar
Zix
The software drivers for the USB/Serial adapter should allow the diagnostic software to work. I've used them when tuning FAST systems (which is serial only) and Big Stuff 3 and they both work without an issue.
To Which Diagnostic Software
