Not holding a charge.
If someone as any idea of what the problem could be I'd love to hear it. Its frustrating at this point and I'd hate to go into the winter season knowing my car won't run when it comes out.
The battery was tested after the alternator was put back in and I was told everything looked fine.
Jason
If the battery goes down overnight, you either have a parasitic drain or a bad battery. New batteries go bad.
Jason
However before the alternator was rebuilt the only code I've ever gotten was the TPS, and the battery was really fine until I found out the alternator wasn't working. When I put the alternator back in I get a new code, I cleared it just to make sure its a problem and not something from not being hooked up for a while, and it flashes code 15. I'm hoping, just because I don't know where to start if this isn't the problem, a sensor would drain power if its not working properly or if the wires are messed up. So I'm not sure if there's an electrical forum or not but anyone with experience here, some help would be greatly appreciated.
If you suspect a voltage drain. Remove the negative battery cable and put a amperage meter between the cable and battery to find out how much drain there is. Make sure no interior lights are on, including the under-hood light before disconnecting the battery. Post back what the amp drain was. We can try and help narrow it down for you.
Not sure where the sensor is on the 85, but wild guess is driver's side head or thermostat housing or water pump, so check for all three.
regarding battery drain, some typical places to look for drain: car seats, antenna motor, or interior lights staying on because door switches have failed.
BTW, a battery disconnected and fully charged, voltage should read 12.6+, but connected and key on, 10.5-11.5 is normal.
From FSM pg 6D1-4
Load Name.................................... Milliamps
ECM Memory.................................. 2.5
HVAC Control Head .........................0.2
HVAC Programmer...........................4.8
CCM Asleep (Key Out).....................1.4
Headlamp Door Control Module..........2.1
Generator Output...........................1.1
Chime Module................................0. 8
Radio Control Head.........................0.6
Radio Receiver...............................1 .4
Total................................... .........14.9
If you get a high reading, pull fuses one by one until you find the one that brings it down to normal limits. Then troubleshoot that circuit.
By the way, it's hazardous to your meter attempting to measure current on a motor vehicle, because an un-planned for sudden load (such as opening a door, a remote being activated, etc.) will at least blow the fuse.
Consider purchasing a 1 Ohm power resistor, and install it temporarily (for troubleshooting purposes) between the battery + terminal
and the + lead. Since I=E/R, measuring the voltage drop across the 1 Ohm resistor will allow you to directly read the current being
used by your vehicle. 1mV=1mA.
Now that is an excellent technique. I will have to remember that one.
Oh yea, the diodes were replaced, I replaced that and the voltage regulator, I was told the rectifier and everything else was just fine. I'm gonna try the fuse idea for sure, that's a really good way to pinpoint that stuff, never would have thought about that one.
I had the Alternator checked again at the local parts store and they again told me its fine but it was mentioned that they will measure voltage not amperage so by disconnecting the negative battery cable and putting an amp meter to it is that the right way to check that? Also should I have the key on the accessories or not in at all?
