I have a fluid leaking on the front left (drivers side) under the radiator. it looks like power steering fluid. I do not see any leaks on the pump or on the resevour? where else could it be from? any ideas?
Originally Posted by MK 82
Explain to me how it makes sense that a leak in the PS rack or cooler starts after you flush the radiator.
Hummmmm, Problably because this statement. Even the simplest of minds can tell the difference between coolant and PS fluid.......I hope!......LOL
R/Noland
I am not reffering that they are related in any way just point of fact. I flushed the cooling system and then the next day I have a clear greasy type liquid that look a lot like PS fluid. I can not see where it is coming from The pump and hoses look dry.
Maybe you have the new coolant type in your car. Perhaps the drain cocky is leaking a little. I forgot the name of the new coolant type, but I know they are not green and look a little brownish in color.
DONT USE STOP LEAK!!!!!!!! Fix the problem instead. I used that stuff and found that the little ***** do not completely dissolve and instead, covered the bottom of my expansion tank with a potential clog.
Originally Posted by shamdave
it is and does but i had the tranny rebuilt and it is not trans fluid it is clear to light brown
The PS is a little low but not much. Does that stop leak crap work
