transmission shift adjust
Old Jan 6, 2002 | 07:38 PM
vettedreams's Avatar
vettedreams
Default transmission shift adjust
Has anyone read the T.P.I.S insider hints book, and if so, the section on adjusting the shift point is not clear to me, I'm having trouble relating what they said to do, and relating that to my '86, I'll most likely contact them but I thought I'd just ask on the forum, thanks
Old Jan 6, 2002 | 08:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: transmission shift adjust (vettedreams)
They are talking about adjusting the position of the TV cable, but I disagree with them. That cable is used to adjust line pressure at part throttle and so alter shift points and speed at part throttle.
To change shift points at WOT you need to change springs/weights inside the tranny.
Old Jan 6, 2002 | 09:00 PM
Vic'89's Avatar
Vic'89
Any Tranny expert will tell you that adjusting shift points by the TV cable is wrong.
The TV cable has only 1 correct setting.
Vic
To transmission shift adjust
