LT1 engine ?
Old Sep 20, 2008 | 01:00 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default LT1 engine ?
I am looking for a engine, mine is about to bite the dust. I keep seeing LT1 engines for sale for Camaro's, etc.., but they all say they will not fit the vette, WHY?
I thought the only difference between the 2, was the 2 bolt main for the camaro and the vette had a 4 bolt main.
Old Sep 20, 2008 | 01:30 PM
aboatguy's Avatar
aboatguy
The accessories and other bolt ons have differences between the B, F and Y bodies..
The short block on B, F and Y are the same and heads on the F and Y bodies are the same, so just use the shortblock/heads from the camaro and use all the other parts from your vette and you should be fine.
Old Sep 20, 2008 | 01:34 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks, did you and Ted have the same car problems?
Old Sep 20, 2008 | 02:04 PM
c92vette's Avatar
c92vette
Default Rebuild the Original
Would't it be better for the value of the car to rebuild the original motor?
Old Sep 20, 2008 | 02:05 PM
aboatguy's Avatar
aboatguy
If your talking about strange panties in the glove box......Yes!
Old Sep 20, 2008 | 04:40 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
The Y lt1 has a 4 bolt main and F body has 2 bolt. I suppose the OP could switch the acc brackets and put it in correct?
Old Sep 20, 2008 | 04:53 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
http://www.enginebuildermag.com/Arti...lt1_enige.aspx
Old Sep 20, 2008 | 04:59 PM
Redeasysport
Wasn't the HB different on the F body too? I know they do not swap and IIRC it sticks out farther not sure if the crank is longer or not or if you can swap the hub and balancer from a 'Vette to the F LT1.
Old Sep 20, 2008 | 05:15 PM
aboatguy's Avatar
aboatguy
The balancer is different/
Crank is the same.
To LT1 engine ?
