New owner - what mods to do first..
Anyhoooo, I wouldn't waste my time bypassing the t-body and descreening the MAF for the following reasons. You won't see a noticible difference and you might even create an issue in the MAF.
The screens are there to make the air flow over the wires in a controlled manner.
I'd drive the car a while, make sure it's sound then attack in a logical manner. When I bought my 95 I made sure it was a keeper, then did the required maint. and some necessary work. Just that adds up quick.
If you're on a budget look at exhaust and an air cleaner before going nuts elsewhere. Just my .02
The TB bypass is just another simple mod. It couldn't hurt and is very cheap to do.
I disagree. The only reason for the screen is to prevent debris from passing through. As long as a good air cleaner is used and the lid is tight, this will never be a problem. Removing the screen increases quite a bit of CFM.
Odds are he'd have an idle issue before he saw a dyno increase by removing the screen...
But hey - Let's agree to disagree
I also understand the need to keep the engine well maintained.
Should I replace/flush the coolant? 33K miles..
Tranny fluid change? It looks good on a stick.
Fuel filter? Anything I'm forgetting?
The same feeling would be accomplished by 3.54/3.73 gears and a 2400-2600 stall TC, and this would knock down those times as well.
Headers/exhaust would take care of the sound, but listen to other catbacks. Headers all give around the same power, and so do most catbacks, the only difference is the sound really.
-Go synthetic in the trans and rear diff
-Cat back exhaust (do a search on this forum, LOTS of info)
-bypass the coolant line in the throttle body
-New plugs and a good set of plug wires (NGK TR55 plugs and MSD 8.5 Wires are a great combo)
-clean the throttle body and the MAF, descreen the MAF
-Seafoam the motor
As far as low end torque, it is kinda hard to do with the LT1 because of the very short runners on the intake manifold. A 2,500 stall 10" converter would be a big change. Do not go too high numerically with the rear gear because first gear in the trans is very steep and you will have problems hooking up on the street and make for a tricky start in the rain.
Good luck
BTW, how smooth stock idle is supposed to be? I'm new to the vettes so for me idle seems rough but..
I appreciate all you guys inputs! Man, it is addictive and fun
As far as the x pipe... by crossing the exhaust you are helping with scavaging sp? the cylinders. Also I think the big deal is that the stock resonator necks down to 2 1/4 and the x pipe I bought keeps you at 2 3/4 throughout. Plus with my aftermarket exhaust it helped with the droning. I wouldnt mess with the cats, I dont think there is a big difference, you get more droning, and you have to find a shop to pass you for inspection.
I ran an L98 for 70K miles without the MAF screens and never had a problem. The hot wires in that one are way more delicate than the LT1 MAF.
Free mods are free mods, so why not? Every little bit helps.
Now, if you can pick up an airfoil for $5.00....
Looks like my list is -
0. Maintenance
1. Computer programmed (faster shifts etc)
2. 3.54 gears
3. 2600 stall convertor
4. Some kind of exhaust - not sure what - corsa or custom or just muffler elim.
Mid to high 12s
0. Maintenance
2. 3.54 gears
Mid to high 12s
There are a couple people here who bought a VERY nice Magnaflow cat back for less than $600 shipped from some vendor. I can't remember the name.
Keep in mind- changing the rear gear is a very expensive job because it is at least 8 hours of labor at a shop. Get a ring&pinion set with a bearing kit. Even though it only has 33K, you do not want this to have to been done again anytime soon.
You might as well replace some of the suspension bushings with polyurethane ones while they are under there.
What will polyurethane suspension bushings do? Any side effects on this?
The stock rubber bushings are now 12 years old. Rubber dries out and rots, polyurethane doesn't. The rear end will feel less loose with the poly bushings. The rear suspension in a C4 has quite a few bushings and that makes for a wiggly ride when they all go.
The only side effect is it may be a little bit stiffer ride, but if the shocks are still the factory ones, it should not be too bad.
Is 3.54 too much?Got 3.07 currently.
I got that selective ride thing, not sure if it matters or not.
Also - is it supposed to be noticible Tour/Sport/Performance - mine is ALMOST the same..
I suggest this: the stock converter is a total dog. Replace the converter with a good one, like a Vigilante or similar. See how you like that. If it still seems like not enough, then do the rear gear.
The selective ride only changes the shocks and has nothing to do with the bushings. Shocks control up and down movement of the suspension. Bushings insulate the up and down and control side to side movements.
To get an idea of what your mileage will be like with lower gears, put the car in 3rd and drive on the highway. Figure a half mpg difference between 3.54/3.73, so choose 3.54 if you drive on the hwy alot.
Stock stall is about 1500rpm.
The MAF screens are there to straighten flow over the sensor element, the air filter is there to protect it, and though L98s do benefit from the removal of the restriction of the screens, the LT1/4 engines rarely do. I would leave this alone.
Poly bushings require a good bit of lube, they squeak alot. It will crispen the handling a bit and the ride quality will go down, but otherwise theres no negative to it.
