Check Engine Light resetting itself
The check engine light comes on everytime I drive it after about 20 minutes or so.
When turning the car off the check engine light resets itself everytime which is preventing me from reading the code. This results in a code 12 everytime.
I have no idea what is going on and it's definitely annoying. The car itself is running smoothly and doesn't appear to have anything wrong. I was thinking it could just be emissions.
I searched this forum and I googled with no success.
Thank you in advance.
Having said all that, I would normally think if a code was set as indicated by the check light that the code should be set as a historical code.
Not that completely familiar with the 91 on board diagnostics and not sure if you have a speedometer display or just get the codes with the flashing lamp. Just food for thought.
But the best thing is to get it on a scanner as mentioned. I also seem to remember someone else that ended up with a bad CTS, seems he said the computer corrected for it before it could actually throw a code.
The car is OBD1 and used the flashing CEL to indicate what the code is. There is also another method I haven't tried where you can put a jumper between the A and B terminals to have the CEL flash and get the code.
I just did a quick search on Tech 1 (google) and didn't find anything. Is that something that is safe to leave hooked up to the car when driving? No clue how people tune the factory chip but could this be another alternative? Have a tuner hook a laptop up?
I'm just throwing stuff out there so I am probably off.
I wouldn't run the car while this is connected.
You don't need a tuner. I purchased a used laptop, bought a cable from Moates, down loaded Tunerpro RT ( a free program) and can watch all the functions (sensors etc.) very nice tool to have. I think my total investment was about $200. including the used laptop.
