OK, this may sound dumb, but I just want to make sure i do this right. For the open airbox setup in my 94, should I unscrew the 3 big screws, then take the entire black metal lid off, leaving the whole filter exposed?
Not quite that simple but almost, you must either replace the one you have (cover) with one with the louvers cut out or cut out the one you have. I purchased mine already cut from MAD. Can also do search on this topic, much info there. :flag
[1] Unscrew the mounting screws, end ones go through to the schroud and middle one holds the top to the main filter cover. [2] loosen the metal hoop retainer that holds the filter cover to the air intake. [3] take the whole filter assembly off. [4] Take filter top off [5] Mark a line 1" in from all the edges on the top. [6] Use a electric hacksaw and cut on the lines marked and then file the edges to get them smooth. [7] You now have a HUGE open area for it to suck air through. [8] Put everything back in reverse order - start it up and ENJOY (it will sound different)
:cheers: P.S. You can paint the cut/filed areas black so there is no silver metal showing
Mojo is probably right in that it doesn't do much for performance. What it does do is allow you to use the entire surface area of the filter. A filter in the stock housing will get dirty in the very small opening where the air actually comes through it, the rest of the filter is more or less wasted. If you open the lid, the same volume of air will be drawn over a larger area, essentially prolonging the useful life of the filter because you are using the whole surface area instead of a part the size of a business card.
That's the way I look at it anyway, as I notice my K&N is getting dirty slowly, uniformly over the whole area instead of one heavily soiled spot. I bought an open lid, one of my first mods.
