94 LT1 distributor installation
Old Oct 6, 2008 | 03:55 PM
RAW1's Avatar
RAW1
Default 94 LT1 distributor installation
Helms book says that I am going to need to loosen motor mounts, remove oil cooler, and raise engine to remove the crankshaft balancer to access the distro. Do I really need to do all that?! (I was hoping that I could get at it from the top, without even lifting the car)
Old Oct 6, 2008 | 04:12 PM
aminnich's Avatar
aminnich
No. You might have to jack it up so you can get under it with a 2"x2" and a hammer to knock the crank pulley off. But that is all.
Old Oct 6, 2008 | 05:21 PM
MikeC4's Avatar
MikeC4
Throw away the book on this job.... Use search function on "Optispark" and you will learn all the tricks. Don't even touch your motor mounts or oil cooler.....also, make sure you replace the Opti seal and the WP seal on the front of the timing chain cover too.......
Old Oct 6, 2008 | 05:25 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
No Corvette LT1's came from the factory with an oil cooler.
I've changed my opti it's not that bad.
Old Oct 6, 2008 | 05:45 PM
MikeC4's Avatar
MikeC4
I've changed mine it's not that bad.
Good point !!! They must have been talking about the tranny cooler, but that beast is way up front.......Helms is a terrable reference manual fro these cars....
Old Oct 6, 2008 | 09:00 PM
RAW1's Avatar
RAW1
My bad. I meant power steering cooler. I always thought that an oil cooler would have been more useful. I am surprised that the base 08's do not have either one.
Old Oct 6, 2008 | 09:50 PM
see4vette's Avatar
see4vette
Just finished putting in my MSD opti distrib in my 92. A 2"x 2" 3' long with a hand drilling hammer from under the car worked great.
Old Oct 6, 2008 | 10:41 PM
pcolt94's Avatar
pcolt94
With my automatic you can not lock the engine (like manual) to tighten and loosen the 3 balancer bolts. So I came up with a method using an impact wrench (I’m sure not original). Using the exact combinations for length of extension, universal and socket I was able to get the impact wrench up in line with the balancer and in between the radiator. Removing and installing the bolts are a piece of cake. I also made up a tap switch for the solenoid so I can hit the switch and rotate the engine while laying under the car on my back to line up the bolt for the socket. There is only one position it fits in to get at one bolt at a time.
Never had to touch the mounts. The tough job was getting the balancer off after the bolts were out. Don’t believe it had been off in +10 years and took me over a 2 day period of a few pounding sessions to get it off the first time (super frozen). As said, get a long rod. Now after light emery and lube it falls off.
Old Oct 7, 2008 | 12:11 AM
MikeC4's Avatar
MikeC4
Originally Posted by pcolt94
With my automatic you can not lock the engine (like manual) to tighten and loosen the 3 balancer bolts. So I came up with a method using an impact wrench (I’m sure not original). Using the exact combinations for length of extension, universal and socket I was able to get the impact wrench up in line with the balancer and in between the radiator. Removing and installing the bolts are a piece of cake. .
No offense, but this is crazy !!! You just need 2 sockets, one goes in the center bolt that holds the hub on, and the other to loosen the 3 bolts holding on the balancer/pully to the hub. Holding the hub center bolt keeps the engine from turning while you are loosening the 3 bolts
Old Oct 8, 2008 | 09:22 PM
pcolt94's Avatar
pcolt94
Different opinions and ways of doing things. For me I like using the power tools and let them do the work. Been a while since I have had the balancer off and might have tried that method but if I did, it did not work for me. Can’t remember if I was able to get both tools on at the same time but I now I am curious and will check it out again.
For me, my method works nice especially on bolts that haven’t moved in 10 years.
Old Oct 8, 2008 | 11:01 PM
MK 82's Avatar
MK 82
Sorry Dude, but Helms publishes the FSM. The Bible.
Good point !!! Helms is a terrable reference manual fro these cars....
Old Oct 8, 2008 | 11:13 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
They may publish it but I doubt they wrote it.
Helms isn't bad but lacks the level of detail the FSM has.
Old Oct 8, 2008 | 11:24 PM
MK 82's Avatar
MK 82
Of course Helms didn't write it. They publish it. Helms and the FSM are one and the same.
Helm, Inc
Old Oct 9, 2008 | 09:30 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
You need to remove the PS cooler if you have the LT4 engine. Trust me, I know this, after two LT1 engines I was wondering why the LT4 balancer would not come off. Obviously, the LT4 has a different (thicker)balancer. Your 94 LT1, stick an allen wrench to prevent the engine from rotating, use a 5/8 remove bolts, remove balancer with a puller or take the 2x2 advice given. Replace all O rings.
Are you installing a new water pump?
Old Oct 9, 2008 | 10:04 AM
NEVRL8T's Avatar
NEVRL8T
Helm, Inc
Old Oct 9, 2008 | 10:16 AM
96GS#007's Avatar
96GS#007
I've never removed the ps cooler to change the Opti on an LT4 car.
Old Oct 9, 2008 | 01:37 PM
RAW1's Avatar
RAW1
Thanks to all for the tips. The good news is that I replaced the plugs, and my problem is solved - so hopefully I won't be attacking the opti any time soon! One of the plugs had a cracked insulator - other than that they looked great - all a nice light tan color. Not bad for a car with 140K miles (plugs, wires and opti were replaced at 80K).
To 94 LT1 distributor installation
Old Oct 9, 2008 | 03:40 PM
Blue 92's Avatar
Blue 92
From the Helms web site:
In Stock - Reproduction of Original Publication
Contains Factory Authorized Service information written by General Motors.
Helms sells it but there is a world of difference between the manuals created by Helms and the FSM written by GM.
Saying Helms and the FSM are the same thing is like saying Simon & Schuster, Inc and Stephen King are the same thing.
Old Oct 9, 2008 | 04:19 PM
MK 82's Avatar
MK 82
Spin it how you want. I bought my Red Genuine GM FSM from Helms. Helm is a bookstore.
For the last time, Helms distributes the FSM. There is no Helms manual. People tend to call the FSM the Helms manual out of habit.
Helm was founded in 1943 as a commercial trade bindery and at the time was the largest bindery in the Detroit area. In 1959 the Ford Motor Company asked Helm to distribute their service manuals after binding them. This launched Helm into the automotive publication fulfillment and distribution business. Today, Helm provides fulfillment and distribution services for Ford Motor Company, all divisions of General Motors, American Honda Motor Company, Jaguar Cars, Isuzu Motors America, Kia Motors America, Hyundai Motors America, American Suzuki, and Florists' Transworld Delivery (FTD). Helm fulfills over 625,000 factory authorized publication orders annually - accounting for over 70 percent of the market. In 1998, Helm strengthened its position as the leading distributor of automotive and motorcycle publications when it launched its web based online ordering system.
Are you confusing Haynes and Helm?
Old Oct 9, 2008 | 05:23 PM
Road Agent's Avatar
Road Agent
