When I change my oil should I pore it in slow or fast?
also... should I wait 24 hours before starting it. I have a freind that said the oil should stabilise B4 pumping threw the engine
Since it is a Corvette, the garage must be sterilized and cleaned. Make sure you shake each bottle of oil slightly before purchasing, making sure there are no bad molecules inside. Only buy the most expensive oil filter the store carries and ONLY from an unopened box, to lessen the chance of having a filter contaminated with bacteria and light damage.
You must stand at a slight angle over the engine bay. The funnel must be sterilized before use and only inserted 1.2" into the valve cover. The oil must be poured at a 84 degree angle, as not to cause the oil molecules to bump into each other, which may cause severe engine damage.
After the 24hr waiting period, you must then start the engine. If you hear any odd sound whatsoever, no matter how minute, you must rebuild the engine!
Since it is a Corvette, the garage must be sterilized and cleaned. You must stand at a slight angle over the engine bay. The funnel must be sterilized before use and only inserted 1.2" into the valve cover. The oil must be poured at a 84 degree angle, as not to cause the oil molecules to bump into each other, which may cause severe engine damage.
As long as your gaskets are good it isn't going to matter how fast you pour it in. Just don't go so fast that it can't get in the hole and spills out every-where, and don't over fill.
I think you need to seek rehab for your friend's drug or booze habits... What is there to stabalize??? Just wait a couple of minutes for it to all flow into the pan to check the level...Other than that there is no reason to wait. UNLESS it has something to do with how many drinks or drugs you consumed while changing the oil.
Don't forget to send the oil to the pope so he can bless it before you pour it in per the above instructions. I hope your only changing oil in the light of the full moon, if not, time for a rebuild.
If this is not an attempt at a joke or an attempt to get a rise out of someone, I highly suggest you rethink your ability to complete this project safely. Remember you will have to raise the car and remove a drain plug as well as the old oil filter. If how to pour the oil is a sticking point, I don't think you or your friend are qualified to perform an oil change due to the high degree of skill required.
"You will first stabilize the oil to the atmospheric, and barometric pressure. This must be done in a hermetically sealed environment, as any foreign, or microscopic anti-body can contaminate the petroleum distillates".
Pour it however fast you want. Just don't spill it. A funnel helps a lot...
Wait til you lower it back to the ground to start it, then only run it for 5-10 seconds. Then check the oil level on the dipstick. If it's low, add a little bit more oil, and repeat until it's near the top of the gauge (maybe 3/4 of the way is where I try to keep mine).
I agree that the rate of oil pouring is the least of your concerns when changing oil. Jack placement, jack stand placement, catching the oil, and re torquing the drain plug properly are probably all MUCH more important.
Just to make sure, have you checked the FSM to make sure the oil change is necessary? Did you follow the diagnosis tree and test the oil? Did you taste the oil?
You sure don't want to just "throw parts" at the situation and change perfectly good oil!
Since you're going to have all the oil drained anyway, you might as well swap out that old tired crankshaft. It's right there on the other side of the oil pan anyway, easy to get to while you're in there, and if you upgrade to a 383, you can put a really cool sticker on the side of your car that says "Stroker." The sticker is worth about 80 horsepower over stock, give or take 5 depending on the color and font. My friend's aunt's brother's cousin's dog's first owner's wife's ex-husband's co-worker knew a guy who had an oil change business and he did that to every car that he changed the oil in just to make them happy so they'd come back. He'll get you a good deal on the oil if you want 'cause he takes the used stuff to put in the fryer at his other job, McDonald's.
From: One day you're a Comet...the next day you're dust... Arkansas
You forgot about having a 20 year old model hold each can between her thighs for two hours prior to pouring through a organic coffee filter into the fill hole one ounce at a time from a silver spoon.
Being a High Performance Corvette.. you are requried to pressure insert the oil at about 120 gallons per Second with the oil at normal engine oil operating temp.. that being about 225 degrees and pre-filter using a 100micro gold filters.
Should you not start the engine up before the oil settles to the bottom of the oil pan.. it will get contamiated and you will have to start over with freshly manufactor oil from the oil fields of Alaska. Or Germany if you are using GC.
If that is being done that way, how will you ever get anything done? I will have other things for that model to hold between her thighs for a couple of hours.
