need help with 4+3
Old Oct 11, 2008 | 05:14 PM
betr10u's Avatar
betr10u
Default need help with 4+3
hi, guys as iam sure you can tell iam new to this site. i got a 1984 vette, with the 4+3 trans. i figured before i have someone look at it, i was wonder if there is a common problem with them? mine seems to shift hard, but not all the time, and when i mean shift hard it seems to slide into gear ok, it just seems like its more of the shifter that gets stuck? any help would be appreciated and iam about to go take some pics before the sun goes down...if you guys are like most forums i know you love pics lol
Old Oct 11, 2008 | 06:52 PM
Chatman's Avatar
Chatman
I'm assuming that you mean that shifting is difficult and requires a surprising amount of force to go in and out of gear. I also assume that your overdrive unit is functioning OK.
The oil or lubricant that you use in the transmission makes a difference with the quality of shifts. The 4+3 transmission is an interesting case because it calls for gm 1052271 and Dexron II in the overdrive unit. The problem is that 1052271 is really for use in the differential as a GL4+ or GL5. You don't need the sulfur in the transmission and it might even be corrosive. A GL4 is OK for the transmission and Redline and Royal Purple have options. I like the Royal Purple option, MaxGear I think, GL4 lubricant. It has worked very well for me on track days and daily driving. The Redline product wasn't quite as good in my novice opinion.
Old Oct 11, 2008 | 07:34 PM
betr10u's Avatar
betr10u
so something as simple as changing the trans. fluid may work? thanks for the post.
Old Oct 11, 2008 | 08:17 PM
car5car's Avatar
car5car
Change to ATF, drive 3 miles change again.
Old Oct 11, 2008 | 09:24 PM
88espo's Avatar
88espo
Are you saying put atf in the manual trans for 3 miles? Please explain. Thanks
Old Oct 12, 2008 | 01:49 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default shifter
Try adjusting the reverse lockout rod and readjusting the shifter arms on your trans. Also, when you push the overdrive switch, be sure you push in the clutch like you would if you were actually moning a lever instead of pushing a switch.
Sometimes the rod ends wear and the shifter isn't quite in neutral when you are passing through neutral when you pick up another gear.
wiggle the rods in neutral, and check for excessive play and or tight link rods.
The gear oil in the trans part is regular 90W gear oil.
The overdrive unit has auto trans dexronIII in it. make sure you drain and refill both units and then recheck after a short drive.
To fill the overdrive, turn the wheels so the internal pump will draw from the overdrive pan and reveal the true fluid level.
Old Oct 12, 2008 | 01:54 AM
captmike13's Avatar
captmike13
Cruise-In IX Veteran
No. ATF in the overdrive only.
The 4spd portion uses 90wt gear oil. The overdrive uses atf. The 4+3 is really two transmissions. A 2spd automatic mated to a 4spd stick. Overdrive is available in 2nd through 4th hence the 4+3.
Hope this helps.
If you don't already have one get the fsm and an owner's manual. The owner's manual will tell you what fluids to put where.
Mike
Old Oct 12, 2008 | 04:04 PM
betr10u's Avatar
betr10u
i was pretty sure i saw in the manual that if you are just driving around to always leave it in overdrive? what do others do?
Old Oct 12, 2008 | 05:21 PM
powerpigz-51's Avatar
powerpigz-51
I use overdrive mainly on the highway. I use the 4 speed in town, on the highway I treat mine like it is a 6 speed, with 3rd OD as "5th gear" and 4th OD as 6th. There is also a kickdown feature, you can just stomp on the gas and the OD unit disengages, so you can go from 4th OD down to regular 4th gear for passing without having to shift.
Old Oct 12, 2008 | 11:13 PM
rodj's Avatar
rodj
For fuel economy
To need help with 4+3
