1985 Corvette
Old Oct 13, 2008 | 02:56 PM
BAD HABT's Avatar
BAD HABT
Default 1985 Corvette
Hello All,
Does anyone know why the windshield wiper blades go over too far and scratch the side of the car?
Lori
Old Oct 13, 2008 | 03:18 PM
85corvettekws's Avatar
85corvettekws
there is a little cover in the middle of the cowl vent area that pops out. if you adjust the little nuts in there you can change how far out the wipers swing. i'm sure there is a better procedure description somewhere, but i found this in a Haynes manual
Old Oct 13, 2008 | 07:52 PM
rons85's Avatar
rons85
It's an adjustment. Actually it's pretty simple to do, really.
More than likely Someone has played with that adjustment to make certain that the two blades don't "crash" as they scissors down, which is a problem with this design. Be careful, if you do play with that adjustment (which moves the Drivers side arm - the passenger side isn't adjustable), that you don't get yourself into crash trouble.
The better "cure" for the crash thing is to use a shorter drivers side blade. Get one a full 2" shorter than it's Supposed to be - this will keep it away from the passenger side arm as they close - even with the linkage adjusted so that the drivers side blade Travel stays on the glass at the far "Up" travel..
You won't even notice the 2" shorter blade in the rain - BTW - try it and see
Old Oct 15, 2008 | 10:29 PM
BAD HABT's Avatar
BAD HABT
Greetings Friend,
I tried your suggestion and it worked! Also, the windshield wiper motor was not secure. When the wipers were in use, they would pull away from the windshiled and smack the side of the car. Now, all is well. I appreciate the time you took to respond to my qestion.
Lori
To 1985 Corvette
