Critique this build. L98
Old Oct 16, 2008 | 05:43 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default Critique this build. L98
89 6 spd
Requirements:
-Stock driveability and appearance, parts must be legal
-Pass Ca. smog both visual and tailpipe with no fudging
-An everyday drivers motor-Go anywhere type deal.Somethign anyone can throw together. Nothing exotic, bix bucks, no headwork.
-Max engine speed 5k+-
383
-2 bolt main, ARP bolts
-Scat 9000 crank, scat I beams, Mahle (or?) forged piston
-0 Deck approx 10:1 with 65cc chamber heads
-HR roller cam in the 214-220 @/050 range (undecided)
-180cc head from Kmart
-Roller tip rockers ratio undecided
-Ported to death TPI base, SLP runners with mucho grinding
-Ported plenum
-1-5/8 shorties (if I can find some)
-Aftermarket catback, precats and all size upgraded.
-24-26 lb injectors.
-Stock TB, paper filter, etc.
Your opinions, guestimates, flames etc.
Dont be shy
Go.
Old Oct 16, 2008 | 05:59 PM
Churchkey's Avatar
Churchkey
Suggest after market steel main caps with splayed bolts. Line bore will be necessary.
Old Oct 16, 2008 | 06:06 PM
Z51L9889's Avatar
Z51L9889
I like the basic package.
With the goals you stated, I think a set of hypereutectic pistons would work just fine and save some buckage for other areas of the build.
I know you said no headwork, but I think a set of mild to moderately ported '113s would work very well on a package as mild as this and fits pretty well with the low buck theme.
As you already pointed out, the stock shorty headers really need to go. I know Hedman used to list a stock replacement 1 5/8" shorty header for 84-91 C4's but that goes back a lot of years. I don't know if it's still available or not. The only other choice is to grind all the weld beads flat and radius the flanges, but that obviously doesn't address the basic problem that the tubes are just too small, especially for a 383.
Old Oct 16, 2008 | 06:24 PM
Corvette Chris's Avatar
Corvette Chris
I'm not all that familiar with Cali's rules & regs. I seem to recall long tubes are a no-no?
Old Oct 16, 2008 | 06:44 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Why not next use next size larger KMart heads? 383's suck a lot of air, right?
To keep streetable, keep duration low -- as you propose, but consider higher lift to fill cylinders. At least you'll give whatever head a better chance to suck in the air it needs for the longer stroke 383.
You might need to go 28-30lb injectors. 26lber's were used on the 350 dyno I showed you recently. You saw how lean it was. That car had ported TPiS heads (flowing similar to 180cc KMart's), and a LargeTube TPI. Similar deal -- but with less-demanding 350 underneath.
Consider the CompCams 268XFI with 1.5 rockers. Lifts would be lowered to .535ish. With a good tune and stock config high-flow cats, I'd think you could pass sniffer. Maybe a AFPR could help (quickly) shift AFR leaner for sniff test? (This assumes '89 ODB1 ECM responds slowly to pressure changes).
For keeping budget as low as possible, consider Todd's advise and talk to Lloyd too.
Old Oct 16, 2008 | 07:36 PM
cv67's Avatar
cv67
St. Jude Donor '05
Saved this yrs ago cant remember the source
Stock.....198.72 cfm
ACCEL.....213.52 cfm
Extrude/ACCEL.....217.11 cfm
Super Ram......220.67 cfm
Holley stealth ram ....275.00 cfm
ACCEL Hi-Flow intake manifold with 3/8 inch radiused inlet....251.51 cfm
ACCEL Hi-Flow intake manifold with runner Stock......215.83 cfm
ACCEL......232.53 cfm
Extrude/ACCEL.........243.21 cfm
Super Ram.....240.24 cfm
Extrude-Honed ACCEL Hi-Flow intake manifold with 3/8 inch radiused inlet....275.83 cfm
Extrude-Honed ACCEL Hi-Flow intake manifold with ACCEL runner....266.94 cfm
I have not flowed this intake, I did it yrs ago. Noone here will flow it by itself but its taken out pretty far . Exit is 1205, will have to make runner gaskets. It was going to go on a smogger 406 I was going to do yrs ago but I sold the car.
180 uses a 1256 type gasket, 195 a 1205 is close.
Old Oct 16, 2008 | 08:08 PM
JackDidley's Avatar
JackDidley
Do it. A low budget motor can work out great if the right combo is put together. I built a 355 for my C3 in 85 that my buddies called the K Mart motor. Turned out great. Won a lot of $$$ with it. Put so many miles on it, the last time I freshened it up I'm pretty sure I could have put .040 pistons in the .030 holes.
Old Oct 16, 2008 | 08:09 PM
mseven's Avatar
mseven
ah....from the old apartment, now show the pic of the k.table full of allumn. dust.
nothing to add, it sounds like it will meet w/the left coast laws.
on the inj., a 24-26 would be fine...the lean stated above doesn't come from a good inj.
I am posting and then out of here before the "copy and paste, rosseta stone/phoenix schooled one" hatchets the thread.....(my bach. and my masters are in education, and not engineering)
Old Oct 16, 2008 | 08:32 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Looks interesting. I think if you can find some 195 heads for around the same price I would go that route.
Old Oct 16, 2008 | 08:41 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Kmart? Wrong heads
Seriously wouldn't the 195's still be better in the midrange?
Old Oct 16, 2008 | 08:54 PM
Calderone's Avatar
Calderone
what about Vortec heads ?
Old Oct 16, 2008 | 10:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
1205 2.09 x 1.28
1256 1.99 x 1.23 (180)
runners will be the challenge/weak link.
Anyone have the inside diameter on the accel/AS&M and SLPs?
Old Oct 16, 2008 | 10:53 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Is this for you? I know you're wanting one of those!!!
Old Oct 16, 2008 | 11:33 PM
96GS#007's Avatar
96GS#007
Can't offer a critique but will offer a shameless plug...
In a week or so I'll have some 5.7" SCAT forged 4340 H-beam rods for sale. I'm building a 383 and am switching to the SCAT Q-lite rods to get more weight out.
$175 shipped. They have less than 10k miles on them. Have them checked, new fasteners and for probably $250 total you have some killer rods.
Will also have some 3/8" 1.6 ratio CompCams ProMagnum roller rockers, self-aligning, ready to bolt on. My AFR heads require non-self aligning.
$220 shipped.
Old Oct 16, 2008 | 11:47 PM
Kool88vette's Avatar
Kool88vette
I failed a visual because of an afpr. The emissions were fine but I still failed.
Old Oct 17, 2008 | 12:02 AM
cv67's Avatar
cv67
St. Jude Donor '05
Originally Posted by SurfnSun
Kmart? Wrong heads
180
.200 138 110
.300 198 158
.400 240 190
.500 260 207
195
.200 137 110
.300 196 158
.400 243 190
.500 274 207
.550 280 211
Looks real similar til about .500+
Old Oct 17, 2008 | 01:58 AM
reoch999's Avatar
reoch999
Oh man, are you serious? Failed because of an adjustable pressure regulator on your fuel line? That's the dumbest law I've heard of since the last presidential debate! What lobbyist got that one pushed through!?! It's total if you ask me. I rarely say this, but I'm SO glad I don't live in "Kallie fawn ya" as the governator calls it.
To Critique this build. L98
Old Oct 17, 2008 | 03:17 AM
GREGGPENN's Avatar
GREGGPENN
1205 2.09 x 1.28
Stock, they are 1.65" in diameter. Officially, SLP says the SLPs are .05" smaller (e.g., 1.60", but I've heard them measured the same).
Part of the deal is the SLPs are worse castings which can be less round. Also, SLPs are shorter than the other two options with the added bonus of being able to be siamesed. Kind of makes 'em a good/bad option. With your porting skills though, I'd look hard at the siamesed SLPs.
According to my "research", siamesing them 3" in a fashion such as CorvettePlenum.com does would raise peak 400-500 rpms. Might be something to consider unless total low-end torque is your goal.
One other thing.... another member did a direct comparo with ASM vs SLP. He said ASM tracked .2 seconds faster in the 1/4. He attributed part of the diff to the poor quality of his castings. But they are 12 yrs old. Newer castings may have improved, but I've heard not.
BTW: What you did to that base.... damn nice. Those holes are BIG!
And, for ideas, here's pretty much what I think you're after......
http://www.superchevy.com/technical/...ion/index.html
Old Oct 17, 2008 | 09:53 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Q: What are the different runner lenghts and port diameters for the different aftermarket TPI runners and bases?
A:
Runner Type
Length (in.)
Port (in.)
Stock TPI
7.250
1.470 round
Lingenfelter/Accel
6.625
1.615 round
SLP cast runners
6.625
1.600 round
TPIS large tube
7.625
1.660 round
TPIS siamese large tube
7.625
1.660 round
Lingenfelter/Accel Super Ram*
4.125
1.870x1.970 "D" shape
TPIS Mini Ram
3.500
2.600x1.350 entry
1.960x1.200 exit
Stock TPI Manifold base
6.375
1.470 round entry
1.960x1.200 exit
TPIS Big Mouth base
6.125
1.750 round entry
2.090x1.280 exit
Lingenfelter/Accel
6.125
1.750 round entry
Super Ram base
2.090x1.280 exit
* Runners only
Old Oct 17, 2008 | 10:45 AM
cv67's Avatar
cv67
St. Jude Donor '05
Thanks, Surf. My concern on the SLPs is getting to the inside turn without cutting them open. If I remember right on the stockers it was near impossible so no matter how much I ground on them if that was unreachable it would be for naught.
Are the Accel/AS&M tubes real thin like stock or is there a little extra material there?
458hp and 534 ft lbs
I understand those are optimized with no accessories, etc but thats basically what Im after, endless torque without all the rumpity rump drama that goes along with it .
