Headlight question
Old Oct 19, 2008 | 05:03 PM
guido7834's Avatar
guido7834
Default Headlight question
A friend of mine with an 87 had problems with his head lights. He manually raised them. Now we want to check the relays. Is there anything you have to do to close them manually? Or will they operate normally if we just have to replace bad relays?
Old Oct 20, 2008 | 08:17 AM
guido7834's Avatar
guido7834
Anybody?
Old Oct 20, 2008 | 09:55 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
To close them manually, turn the black **** located on top of the motor. Check your owner's manual for manual headlight operation procedures.
Old Oct 20, 2008 | 10:14 AM
Jimbo3087's Avatar
Jimbo3087
I suggest changing the relays... I just went through that with my 84.. I was ready to spend $600 but finally got the relays in and sure enough they worked...
Old Oct 20, 2008 | 03:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/Headlight%20Doors.pdf
Old Oct 20, 2008 | 08:03 PM
guido7834's Avatar
guido7834
Yes, I had same problem with my 87. Changed relays, and problem fixed. Just wasn't familiar with the manual headlight operation. Will try new relays. Thanks
Old Oct 23, 2008 | 10:59 AM
19774x4's Avatar
19774x4
Default relays
where are the relays located?
Old Oct 23, 2008 | 08:04 PM
guido7834's Avatar
guido7834
In a black plastic box in front of the driver side wheel well. Just above the vacuum storage "ball". 2 actuator relays and an isolation relay.
Old Oct 23, 2008 | 09:46 PM
AGENT 86's Avatar
AGENT 86
That is true for 84-87, but I think it was in 88 when they changed the relays to one module.
Can't help with the location, but I'm sure the search engine can help him.
Old Oct 24, 2008 | 09:47 AM
onedef92's Avatar
onedef92
My '92 has that single relay in the exact, same location.
To Headlight question
