1987 Vette - Under Hood Lights Question
Old Oct 21, 2008 | 07:55 AM
rpgibbs1022's Avatar
rpgibbs1022
Default 1987 Vette - Under Hood Lights Question
One of the 2 underhood lights is not working (worked several days ago). Switched bulbs and both bulbs ok but pass side still out. Noticed there appears to be another "solid bulb" at the top of the socket and suspect may be the problem. Questions is; are there any other replaceable parts in the light housing other than the bulb itself? Thanks
Old Oct 21, 2008 | 08:03 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Solid Bulb In Housing
There is a mercury switch in each housing.
Old Oct 21, 2008 | 08:09 AM
rpgibbs1022
Default Mercury Switch
Is that switch replaceable and does it come out?
Old Oct 21, 2008 | 11:17 AM
85corvettekws's Avatar
85corvettekws
If you make incorrect connections like I did when I tried to repair my underhood lights, they will stay on all the time. I ended up having to buy new housings to correct the problem.
Old Oct 21, 2008 | 12:48 PM
floridamale's Avatar
floridamale
It looks like the lead in a bullet not sure if its replacable, I have on & off switches on my underhood lamps
To 1987 Vette - Under Hood Lights Question
By Michael S. Palmer | 2026-06-03 11:00:24
