Now that's pretty stinking cool and a very representative view. It'd be great to show the wife, just how the whole shebang goes together. Now if only you can click a button and start adding the AIR pump, AC Compressor, AIR diverter valves, vacuum hoses, etc, etc (but then you'd hardly be able to see the motor )
A tpi wont make any horsepower but an experienced engine builder can build a fuel efficient torque monster outta one. Had a 1992 camaro with a built 4 bolt 383 sbc with dart iron eagles and a completely stock tpi system save for injectors, throttle body, chip and fuel pump. She had 590 lb ft torque. It wasnt a low speed acceleration machine but it would mop the floor with people at highway speeds between 70-150 with 2.73's. Best of all 33 mpg at 105 mph cruising speed in a camaro! Top speed 179 mph.
Would it be faster with a miniram? sure
But if you have to run it on a built engine, or if your autoxing with it, they're fine.
Yeah, I've heard of TCC. It's one thing to build a setup to the limit of the rules (if you're not cheating, you're not tryng), but quite another to blow money on a built motor and choke it when you don't have to.
I've been doing it all wrong! I thought I wanted my intake to flow. Like I said above, you CAN force a setup to breathe through a restrictive intake if you have to, but that doesn't mean there isn't a better way to do it.
I am going to attempt to take a ported to the max TPI base, aftermarket runners and flow them on a few aftermarket heads to really see whats what. Should be interesting.
