1pc or 2pc??
Old Oct 27, 2008 | 03:00 PM
pearlvett's Avatar
pearlvett
Default 1pc or 2pc??
Ok so the L98...1 peice rear seal or 2 peice rear seal? I have been wondering this since the day i started looking at stroker kits because that seems to be the big question.
Old Oct 27, 2008 | 03:02 PM
Mojave's Avatar
Mojave
86 and earlier are 2 piece rear main seal
87 and later are 1 piece rear main seal
Old Oct 27, 2008 | 03:13 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
85 and earlier are 2 piece.
Old Oct 27, 2008 | 03:15 PM
Mojave's Avatar
Mojave
Damn, I can never remember if its 86 or 87, and Wikipedia said 87, so I went with it.
Never mind, nothing to see here....
Old Oct 27, 2008 | 03:41 PM
BLOCKMAN's Avatar
BLOCKMAN
Eneve the one peice seal block you can use the 2 peice seal crank in with the right adaptor.
Old Oct 27, 2008 | 03:56 PM
cmcbunch's Avatar
cmcbunch
I have this configuration on the 383 going in the vette. It is a one peice rear main seal block with a two peice crankshaft. I forget who made the adaptor.
Old Oct 28, 2008 | 07:34 AM
856SPEED's Avatar
856SPEED
Old Oct 28, 2008 | 09:32 AM
todd_vette's Avatar
todd_vette
Isn't it that some 86s are 1 and some 2???
If aluminum heads and roller cam then 1pc???
Earlier 86s with iron heads 2pc???
Convertables all 1pc???
I could be wrong but alot of things seem to have been mixed up in the 86s.
Old Oct 28, 2008 | 03:36 PM
vader86's Avatar
vader86
All 86s are 1 piece rear main.
86L have aluminum heads, no roller
87 gets roller
Old Oct 29, 2008 | 04:37 PM
pearlvett's Avatar
pearlvett
Ok cool thanks! So if im doing an engine build on my 85 i need the 2 piece?
Old Oct 30, 2008 | 12:35 AM
rodj's Avatar
rodj
Canton and GMPP do crank adapters
Old Oct 30, 2008 | 09:36 AM
BLOCKMAN's Avatar
BLOCKMAN
You can buy adaptors for the earlier pans or the late ones as well.
Old Oct 30, 2008 | 11:18 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Yep, but obviously to do it right with your 85 block, you need a 2-piece. (Assuming it is stock.)
However, depending on your plans it might be worth 250$ to pick up a new 1pc block set-up for a roller cam. The cost of a retro-fit conversion is much more expensive than the cost of a used 350 core.
Old Oct 30, 2008 | 12:07 PM
BLOCKMAN's Avatar
BLOCKMAN
I believe that the 79 through 85 are right side dipstick blocks and are 2 peice rear seal blocks
To 1pc or 2pc??
