need help with 1990 horn problem
Old Oct 30, 2008 | 07:47 AM
racingcanuck's Avatar
racingcanuck
6th Gear
Default need help with 1990 horn problem
I am looking for some help with a horn problem on my 1990 c4 . Horn quit working and i need some trouble shooting tips to track the problem . Any thing would be helpful . THANKS
Old Oct 30, 2008 | 11:17 AM
pcolt94's Avatar
pcolt94
A small list of common items to check:
1 – Fuse.
2 – Horn relay, either check with external voltage on bench and check contacts, replace.
3 – Horn, check with ohm meter or external 12 volts.
4 – Horn contacts in steering wheel, disassemble and give it a visual inspection. Sometimes the switches or contacts fall apart with time.
Old Oct 30, 2008 | 10:51 PM
pipe's Avatar
pipe
My horns wouldn't work after awhile either. And it was the connector in the steering column. Was a pain to remove all the junk in there to get to it. I think it cost somewhere between $20 and $30 Pipe
Old Oct 30, 2008 | 11:58 PM
pletzvet's Avatar
pletzvet
Make sure that your OEM security/alarm system is working properly too. A blown fuse located behind the DIS was the culprit with my 85. I realize the 85 and 90 security systems are not the same...
Old Oct 31, 2008 | 04:28 AM
car5car's Avatar
car5car
Disconnect wires from horns and check if voltage is getting there when you push button. I just installed new horns (10 doll each)
To need help with 1990 horn problem
