Header gaskets for LT4
Old Jan 12, 2002 | 06:29 PM
Rolla Dunkin's Avatar
Rolla Dunkin
Default Header gaskets for LT4
IM in the middle of installing Hooker shorties on the wife's LT4 and have a little snafu as normal.I have two different sets of Felpro header gaskets and either one of them fits worth a $#@!,the only one that fits well is the factory metal ones has any one used these with headers with succes if not what are you using. :confused: Thanks
Old Jan 12, 2002 | 07:25 PM
VMAX451's Avatar
VMAX451
Default Re: Header gaskets for LT4 (Rolla Dunkin)
I'm using the thick paper ones that came with them. I tried a set of mr. gasket copperseals but the embossed "rings" did not mate properly with the header ports and they leaked like mad as a result (the rings kind of "fell" into the ports at the corners if that makes any sense). Everyone says the paper ones are crap and they probably are but I've had them on over a year and they're still sealing fine. The separate flanges on these headers make it a pain to get them to seal since they're never quite straight after they weld up the pipes at the factory. I don't know why they didn't use a thick one piece flange like on most headers. Let us know if you find a solution.
Old Jan 12, 2002 | 11:18 PM
RichS's Avatar
RichS
I'll post tomarow with the # I use for my LT4 and DRM headers.
Old Jan 13, 2002 | 03:22 AM
vetsvette's Avatar
vetsvette
Default Re: Header gaskets for LT4 (RichS)
I used the FelProgaskets when I installed my headers. Don't remember the # but they were blue with D shaped ports. Worked fine. I'll try to find my receipt and post the part#.
Old Jan 13, 2002 | 12:14 PM
RichS's Avatar
RichS
Default Re: Header gaskets for LT4 (vetsvette)
Fel-Pro #1406 :cheers:
Old Jan 13, 2002 | 02:37 PM
90pololt4's Avatar
90pololt4
I have the Hooker header with the Fel-pro gaskets as well. I used a Demel tool and trimed the inside of the gasket to match the port openings of the head. I was showed how to do this by another LT4 racer. Go slow and they work great.
Old Jan 14, 2002 | 01:26 AM
ezmoney92's Avatar
ezmoney92
Default Re: Header gaskets for LT4 (90pololt4)
I have Hooker super comps. and the graphite gaskets that SLP sells for their headers are the 3 sepperate gaskets per side and they seem to fit and seal fine. :seeya
To Header gaskets for LT4
