Help starting car withou coolant.
Old Nov 9, 2008 | 08:05 PM
pt's Avatar
pt
Default Help starting car withou coolant.
Well I had an oil leak right on the seal of the opticspark and some of the oil got into the optic. I open the optic up and it was full of oil. I'll post pictures later. Now, is it ok to start the car with connecting the water pump/ adding coolant? and also no belt. I just want to make sure the optic works without putting everything back together.
Old Nov 9, 2008 | 08:17 PM
engle1147's Avatar
engle1147
I've done that with a car with iron heads but never with aluminum heads or block. Should be fine to run it for 20 seconds or so.....I would think. Let it cool on its own before adding cold H20.
Old Nov 9, 2008 | 09:58 PM
pt's Avatar
pt
Default coolant
Thanks. well the car started right away and turned it off within 5 secs. I'll be putting everything back tomorrow.
Old Nov 9, 2008 | 10:35 PM
Ed Ramberger's Avatar
Ed Ramberger
How many forums are you going to post this question in?
Old Nov 9, 2008 | 10:46 PM
pt's Avatar
pt
Default coolant
LOl well I noticed I posted it on the wrong forum and I didn't know how to move it to the tech part.
To Help starting car withou coolant.
