knocking sound ?
Old Nov 11, 2008 | 12:06 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default knocking sound ?
When I use Datamasters my knock count is just crazy, my question is can my new Bosche III injectors be causing the count to be so high?
They are extremely noisy.
Old Nov 12, 2008 | 12:46 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
ttt
Old Nov 12, 2008 | 01:02 PM
rick lambert's Avatar
rick lambert
Guess I'm going to say, if it's the injectors that would be the first time I've heard on noisy injectors causing a problem with the knock sensor.
Think I would check the sensor first including wire routing. And then I'd check base timing.
At least MO will get you ttt.
Old Nov 12, 2008 | 06:42 PM
JackDidley's Avatar
JackDidley
Not likely the injectors. Can you define just crazy ?
Old Nov 12, 2008 | 07:46 PM
engle1147's Avatar
engle1147
I put the Type II in my '89 in '07 and the knock sensor counts went up high enough to set a code....I think it is like ~35 counts or so. Ran the car for a day and the knock counts were gone. I reset the stored code knock code and have been good ever since. The Bosh II's are a good bit louder than the stock multecraps.
Old Nov 13, 2008 | 09:43 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
My knock counts are at 45k+ in under 2 minute, on the datamaster.
Old Nov 13, 2008 | 09:53 AM
engle1147's Avatar
engle1147
What octane gas are you running.....since the switch to ethenol here in Florida I know I can only use the mid grade or higher.......else the car stumbles and doesn't have pep for crap. True, I could adjust my timing to compensate for it a bit... but I don't think you have that option. Blended gas shouldn't make a difference...is what I hear on the streets...I disagree.
To knocking sound ?
