Open Air Box worth it?
Old Nov 15, 2008 | 06:57 AM
99custom's Avatar
99custom
Default Open Air Box worth it?
I was debating if cutting up my airbox on 94 vette was worth it or not?..Also how much do you remove? Thanks
Old Nov 15, 2008 | 08:15 AM
engle1147's Avatar
engle1147
It is worth a couple hp. You can buy a new cover or cut yours to look like this: http://www.ecklers.com/product.asp?p...dept%5Fid=1756
Old Nov 15, 2008 | 11:41 AM
99custom's Avatar
99custom
Sweet...Thanks....
Old Nov 15, 2008 | 01:03 PM
Yorcci's Avatar
Yorcci
That's how much I cut my '91:
Old Nov 15, 2008 | 01:09 PM
LKoncar's Avatar
LKoncar
Save yourself some money and cut your lid like Yorrci's pic. I did mine cleaned the sharp edges and painted. Just cost me a can of paint
Old Nov 15, 2008 | 06:43 PM
Aardwolf's Avatar
Aardwolf
Some say it helps. There was a dyno done on a few filters, here:
http://forums.corvetteforum.com/c4-t...o-results.html
Old Nov 15, 2008 | 06:55 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On the L98s the cut lid with hi-flow air filter has been shown to add about 10chp.
Old Nov 15, 2008 | 07:36 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I did that on mind, and can say I haven't felt difference.
Old Nov 15, 2008 | 07:48 PM
Aardwolf's Avatar
Aardwolf
What do you think about the above dyno on the filters? Do you have any dyno or time slips showing a gain?
Old Nov 15, 2008 | 10:26 PM
whalepirot's Avatar
whalepirot
Where is that showing?
What is chp?
Old Nov 15, 2008 | 10:30 PM
whalepirot's Avatar
whalepirot
Being ready to move to the '87 stock intake, I am quite interested in feeding my monster.
This is what I would expect.
I'd like to know, where is that showing?
What is chp? Oh, crankshaft HP?
Old Nov 15, 2008 | 10:32 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
What is chp?
YES it's worth it because it will take a total of about fifteen minutes and it doesn't cost anything other than a rattle can of black. CHP is Crank Horsepower. It will get you a couple of ponies for certain, enough to feel a difference, absolutely not. It all starts with one stupid mod then it's a converter, some gears , a stroker then a little spray
Just log off and never come back, these bastages on here talked me into spending thousands of dollars
Old Nov 15, 2008 | 10:50 PM
Eddie & the Cruisers's Avatar
CHP is California Highway Patrol!
All 10 of them will come get you for making more sucking air noise.
Old Nov 15, 2008 | 10:55 PM
whalepirot's Avatar
whalepirot
I was afraid of that. So far, no tix since the one 15 years ago.
The huge sucking noise exists now, without the cone on the TB!
Old Nov 16, 2008 | 12:46 PM
65Z01's Avatar
65Z01
Yes "chp" == "crank HP".
You won't likely "feel" a 10chp gain and maybe not even a 20chp gain but it will show up in 1/4 mile time slips as trap speed increase, assuming you can get consistent passes and the weather is the same between tests. That is, 10chp == 1mph gain at the traps and about .1sec off the ET.
There are time slip data and two dyno pulls on my site.
Old Nov 16, 2008 | 01:26 PM
pologreen1's Avatar
pologreen1
I would say if you are just going to cut it, go for it, but if you are going to spend 50 to 75 on a air filter element I would wait and spend 150 on a used claw and start there if you care or you are only having high hopes or feeling like a mod!
Old Nov 16, 2008 | 03:46 PM
Aardwolf's Avatar
Aardwolf
Which ones? I went and looked, I noticed several mods done at once with no way of knowing what did how much.
To Open Air Box worth it?
Old Nov 16, 2008 | 04:07 PM
Red Tornado's Avatar
Red Tornado
the open air lid will serve to dirt-clog up your filter and nothing positive that's even worth mentioning.
i put my homemade one in the basement, and will give it to the next owner of my '90 when its sold.
Old Nov 16, 2008 | 05:49 PM
Iroc57's Avatar
Iroc57
You think that you have it bad....look at what these and another forum's bastages made me do
Old Nov 16, 2008 | 07:49 PM
janarvae's Avatar
janarvae
Is that a big block?
