Possibly serious issue
Old Nov 18, 2008 | 06:19 PM
Red85L98's Avatar
Red85L98
Default Possibly serious issue
Under heavy acceleration the car will run smoothly then all of a sudden lose some power and the check engine light will turn on. It will still accelerate but feels more Honda civic-like. doesn't seem like the clutch is slipping, doesn't rev disproportionately to acceleration, just slows down. Any help would be appreciated.
Old Nov 18, 2008 | 06:47 PM
JimiHendrix's Avatar
JimiHendrix
Does your car throw codes? If so, maybe the reason for the check engine light is stored in your car's computer somewhere.
Old Nov 18, 2008 | 06:48 PM
JackDidley's Avatar
JackDidley
First thing is, check for codes. Also check fuel pressure. Those 2 things will give you something to go on.
Old Nov 18, 2008 | 07:02 PM
StealthLT4's Avatar
StealthLT4
Is it tied to a single RPM range? If the engine seems to suddenly cut out at a certain RPM, it could be injectors. I agree though, check the codes first.
Old Nov 18, 2008 | 08:22 PM
rickneworleansla's Avatar
rickneworleansla
Could be anything. Get the codes. Mine was doing something similar at one point. It ran fine but under heavy acceleration it would fall flat and run like a 4cyl. After a few days I discoverd this in the pic below.
The air duct was cut and on heavy acceleration it would cut off the air supply.
Old Nov 18, 2008 | 08:39 PM
VetteSlave's Avatar
VetteSlave
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
That looks like one of them super low quality crap "power couplers" out of Mid America. A 100% total piece of junk!
Old Nov 19, 2008 | 10:02 AM
Calderone's Avatar
Calderone
i like the super couplers in fact im getting one
Old Nov 19, 2008 | 10:06 AM
rickneworleansla
Yep, it's from midamerica and it is a big piece of junk. The piece on the TB side is sort of holding up except for where the nitrous line goes in. It is starting to crack there. I wasted $40 a piece on those.
Old Nov 19, 2008 | 10:09 AM
Calderone's Avatar
Calderone
i like it because it doesnt look so dated as the accordeon one
Old Nov 19, 2008 | 10:15 AM
rickneworleansla
I also like the looks and the smooth insides but it's not much good if it doesnt last. Unless I replace it every two years for another $80.
Old Nov 19, 2008 | 10:29 AM
VetteSlave's Avatar
VetteSlave
Hot Rod Ron will tell you that they didn't last even six months on my '96 before cracking and falling apart. They are made from inferior materials and are just JUNK. Don't waste your time or money to find this out the hard way, especially if you are running a de-screened MAF!!!
Old Nov 19, 2008 | 07:48 PM
Red85L98's Avatar
Red85L98
I remember the guy i bought it from saying it doesn't throw codes, but its in the shop now for a rear main so ill have them check fuel pressure as well. Took it to a friends garage a week ago and he said everything was fine, now I'm in for a rear main, possibly injectors and he left my tranny, o/d unit and rear end almost bone dry.
Old Nov 20, 2008 | 12:20 PM
MikeC4's Avatar
MikeC4
Bogging down and loss of power during hard acceleration can be caused by clogged cats. Get them checked out as well.
Old Nov 21, 2008 | 06:02 AM
93 ragtop's Avatar
93 ragtop
also, a stopped up fuel filter will cause it to loose power on the top end. But usually with that, it is a miss as well. Again, I would look hard at the converters.
Old Nov 21, 2008 | 11:39 AM
engle1147's Avatar
engle1147
Check for stored codes should be the first step. Most auto part stores will check them for free.
Sounds like the fuel pressure regulator (FPR) is busted....but this shouldn't really throw a code....
Old Nov 21, 2008 | 11:47 AM
TA's Avatar
TA
Knock sensor?
Old Nov 21, 2008 | 01:11 PM
MikeC4's Avatar
MikeC4
Originally Posted by TA
Knock sensor?
Knock sensor who ?
To Possibly serious issue
Old Nov 21, 2008 | 04:29 PM
Red85L98's Avatar
Red85L98
I had the cat gutted and a new fuel filter put in about a month ago, i smell heavy fumes when it happens...
Old Nov 21, 2008 | 04:30 PM
Red85L98's Avatar
Red85L98
and it happens like once every week or so, so its not a frequent thing
Old Nov 21, 2008 | 07:14 PM
MikeC4's Avatar
MikeC4
Gutted your cats, sorry, you have lost my support and confidence...
