1988 headlight not rotating fully
This is on the driver's side. The passenger side works fine as always. I was concerned with the little metal stopper piece that has a "T" marked on it that goes around the motor shaft. I didn't notice the orientation of this piece before I took it out so I looked up a picture online and put it in that way. The passenger's side doesn't appear to have this piece so I don't have anything else to go by. Should the passenger side have this piece also and, since it doesn't, could I take it completely off of the driver's side?
I guess, before I do that, the question is could this be causing my problem and if not what else could it be?
Also, do you think momma will be happy that I got rid of the original problem and overlook the new one?
It worked fine before except for the post rotation spin/click.
Order a set of these for each light that has a problem:
http://www.ecklers.com/product.asp?p...4&dept_id=1476
There is a "sticky" on top of the C4 Tech and Performance page by Shrade that explains the repair.
Sounds like you may have gotten the arm swung around on the motor for the drivers side. Follow the instruction on the sticky notes.
Good idea about the arm though. I hadn't thought about that. I hadn't even noticed that you could swing it around the wrong way. Can you? I'll check that out. Thanks.
post edit: maybe you're talking about the little part that the roll pin goes into that attaches to the motor shaft. I'll have to look when I get home but I may have that backwards.
