code reading
Old Nov 23, 2008 | 11:35 AM
mjb1019's Avatar
mjb1019
Default code reading
How do you read the codes on a 1987?
Old Nov 23, 2008 | 02:53 PM
guido7834's Avatar
guido7834
Do a search on "codes"
Old Nov 23, 2008 | 04:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Locate the ALDL under the DS dash to the right of the steering wheel.
Remove the cover (if still there), use a bent paper clip legs to jumper Pins A&B (two upper right).
Turn On the ignition key (do NOT start the engine).
Count the SES flashes: you will see three "12"s followed by each code flashed three times, ending with three "12"s.
Turn Off the ignition key.
Remove the paper clip.
Install the ALDL cover.
Old Nov 24, 2008 | 08:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/No...it%20Check.pdf
To code reading
