Removing cats worth it?
Nov 24, 2008 | 02:16 PM
I have a 94 vette stock exhaust with 2 brand new cats....I needed them too pass emissions...I don't need to pass for another 2 years now so I was thinking of removing them and putting in some straight pipe...Is the gain worth it? Lose alot of torque? I was going to do this while installing a new magnaflow SS catback system....(I would obviously keep the cats around for emissions)
THANKS
Nov 24, 2008 | 02:17 PM
St. Jude Donor '05
It will be a little louder, thats it.
Modern cats dont rob power like the 80s style ones did
Nov 24, 2008 | 02:20 PM
LT1 exhaust isn't as restrictive as L98, so you won't be able to tell a difference in performance by removing the cats. It will be louder, and the exhaust will smell a bit, but that's about it.
If I was in your situation, I would keep the cats on unless you can get a cheap set of bullet cats. It's not worth the gain, I can assure you.
Nov 24, 2008 | 02:32 PM
Another vote to keep them on
. Otherwise your car will smell like a beater car.
Nov 24, 2008 | 04:51 PM
Quote:
Originally Posted by
Raysur
Nov 24, 2008 | 06:38 PM
Iroc57
Nov 24, 2008 | 07:32 PM
GS023
Thanks guys...I'll keep them on...I don't want it smelling like my neighbors Mustang
Nov 24, 2008 | 07:36 PM
Master__Shake_
well i have an L98, Worth it for me?
Nov 24, 2008 | 07:48 PM
Red85L98
for me I bought duals straights from mamo and it was a major difference in power, and sound! well worth the money!
Nov 24, 2008 | 08:30 PM
pologreen1
..... but my car smells funny w/o the cats....its got that ol' school no cat smell.
Nov 24, 2008 | 10:12 PM
engle1147
mine smelt terrible when I got it, now I can blast the exhaust way out!!! no complaints here as long as not idleing in the garage too long!
Nov 25, 2008 | 01:54 AM
Get some long tube headers and ditch the cats. Get rid of the resonator while you're at it.
Nov 25, 2008 | 04:16 AM
Cruise-In II Veteran
David Vizzard has shown that the engine needs around 2.2cfm of exhaust flow per 1chp; below that back pressure begins to rob power.
So a 300chp stock LT1 needs 660cfm and a 240chp stock L98 needs 530cfm of exhaust flow.
Nov 25, 2008 | 07:06 AM
65Z01
Does Mr. Vizzard have flow numbers for various configurations and muffler manufacturers as well
Nov 25, 2008 | 09:21 AM
get rid of 'em no more litter box to change no more clawed up furniture and you save money on cat food.
Nov 25, 2008 | 04:40 PM
dclafleur
Nov 25, 2008 | 04:56 PM
Red85L98
Only you can judge whether its "worth it", but I can tell you there's a much more significant gain in a L98 car
Nov 25, 2008 | 05:02 PM
po gutted the pre cats,
if the dreaded drone is what you want, then go for it
Nov 25, 2008 | 09:38 PM
Unless your sitting with your face in the exhasut pipe and the engine running theres no extra exhaust smell around the car.
Nov 25, 2008 | 10:02 PM
rickreeves1
I'm using high flow cats and LT headers and there was a noticable performance increase with an other wise stock engine. At higher HP levels the factory exhaust becomes an issue.
Mike
