1989 corvette dies
Old Nov 28, 2008 | 11:18 PM
tx mike's Avatar
tx mike
Cruising
Default 1989 corvette dies
Mechanic said that I was not getting 12 volts to MAF and there was a poor pulse on the injectors. Any help are suggestions is appreciated. Thanks!!
Mike
Old Nov 29, 2008 | 12:09 AM
engle1147's Avatar
engle1147
Mike
No 12v on the MAF....you should change the 2 relays for the MAF: the burn off relay and power relay.
Always check your car for trouble codes first, check your fuel pressure @ the rail.
'89's are known for problematic Multec injectors.....get them out of there!
Fire your mechanic and buy yourself your own 1989 FSM (factory service manual) and fix it yourself.
There is a used FSM in the C4 parts section for sale:http://forums.corvetteforum.com/c4-p...ce-manual.html
Old Nov 29, 2008 | 08:10 AM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Mike
get yourself an ohm meter and check the injectors yourself, its easy and free. Also, its probably your problem
HOW TO OHM CHECK YOU INJECTORS
Old Dec 6, 2008 | 01:31 AM
tx mike's Avatar
tx mike
Cruising
Default solution
Finally, autozone sold me a bad ECM. Vette back on the road and running. Thanks so much for all your help!!
Mike
Old Dec 6, 2008 | 07:10 PM
tx mike's Avatar
tx mike
Cruising
Default I spoke to soon
I put new ECM in and it ran good while driving it around for about 30 minutes. The next morning after running it for about 10 minutes it went back to the same problem: When I give it gas it dies!
I believe it got a power surge of some kind to the ECM (probably damaging it again). Any suggestions is appreciated!! Thanks!
MIke
Old Dec 6, 2008 | 07:31 PM
mako41's Avatar
mako41
I suggest you follow the advise posted above, check your fuel presure and your injectors!
I can almost guarantee those OEM Multitechs are bad.
Old Dec 7, 2008 | 06:13 AM
tx mike's Avatar
tx mike
Cruising
Default not fixed yet
I believe new ECM gone again. Poor pulse again. Any suggestions is appreciated!! Thanks!
Mike
Old Dec 7, 2008 | 01:32 PM
seenalot's Avatar
seenalot
INJECTORS
Shorted Multitecs are sensed by ECM and it shuts the bank down. I had bad injectors in BOTH banks and ECM would shut the whole engine down
FICINJECTORS is the expert on injectors, has helped more members and sells great products. Do a search on this forum regarding injectors tx mike and you'll learn valuable info.
Old Dec 21, 2008 | 03:48 PM
tx mike's Avatar
tx mike
Cruising
Thanks everyone for your help. Also, thanks to Jon at FIC for the bosch injectors. So for so good. Car running great.
Mike
To 1989 corvette dies
