Fuel pressure drop after injector install.
Old Nov 29, 2008 | 12:20 PM
EastCoastHD's Avatar
EastCoastHD
Default Fuel pressure drop after injector install.
Yesterday I installed my Bosch III's from Jon @ FIC.
Install went perfect, until I performed a leak test!
Initially the system pressurizes to about 44 psi, then drops to 20 psi in 20 secs. (from 44to 10 in 1 min.) No leaks to be found anywhere.
I then perform a leak down test by pinching off the return line (when standing at the rear, facing the tank fill, the bottom hose that enters from the right side, correct?) the pressure then goes to 66 psi, down to 60 after 6 mins. I then manually bleed of pressure to 44 psi where it holds beyond 20 mins. I understand this points to a faulty FPR. I installed a new diaphragm previous to the initial leak test. So I removed and reinstalled the diaphragm just to be sure. Same results with return line not pinched, rapid pressure drop!
I dont think I'm missing anything, just looking for tips before I go and spend $120 on a new FPR assembly and pull the fuel rails apart
A couple notes,
The car is not running, I have the dist. pulled (replaced intake gaskets) and valve covers off, waiting for my valve seals to arrive.
Also, the FSM states that fuel press., with the return line crimped, should be 60 psi. I'm getting 66 psi ?
Thanks, Ron.
Old Nov 29, 2008 | 12:54 PM
John A. Marker's Avatar
John A. Marker
Your problem is not the FPR, expecially if you just replaced the diaphram. It has to be your check valve in the fuel pump. This is like a anti-back flow valve.
engle1147's Avatar
engle1147
A couple notes,
Thanks, Ron.
You have a leak in the system somwhere....I doubt it to be the new injectors. There is also a fuel pulastor module (just above the fuel pump in the tank) that have been problematic for other CF members and there is the checkvalve in the fuel pump itself that may have a problem.
Don't wory about the extra 6 psi on the pinch test...sounds like the regulator is doing its job.
Old Nov 29, 2008 | 01:29 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
A couple notes,
Thanks, Ron.
ron
the leak test prior to starting the engine is to find leaks. the rail, injectors and lines are full of air, untill you pulse the injectors there is no way to get the air out unless you purge it through the schraeder using the release button on the guage if you have that type. It will act just like a brake system wiith air, you pump the pedal it holds pressure because you are compressing the air. release it and the pedal goes right to the floor/ try to bleed the air.. if you need me I am on my cell
770 842 0882
Jon
Old Nov 29, 2008 | 04:30 PM
EastCoastHD
John, I did consider this. I think however that it is more than likely located in the pump itself and requires pressure to move the check ball of its seat. My problem (or so I thought) is on the return (low pressure side)completely isolated from the pump.
Thanks. Again, the pulsator is located on the pressure side. The system maintains pressure when pinching the return, it cant be bleeding pressure on the inlet(pressure) side
Originally Posted by FICINJECTORS
ron
770 842 0882
Jon
Jon, thanks for the phone call and setting me straight on my issue
For the record, Jon phoned me a little over an hour after posting this thread. My problem is that until the car is running or the fuel pump is continually energized while bleeding the fuel rail, the system is air bound and will not hold a static pressure. Duhhhhhh!
I have a few more things to do before I can fire it up, probably within a couple weeks. I'll post an update.
Thanks again everyone! Ron
To Fuel pressure drop after injector install.
