Hood Latch Release problem
Old Dec 3, 2008 | 12:34 AM
dredd0822's Avatar
dredd0822
Default Hood Latch Release problem
Whenever I pull the hood release in my '84 and then try to pull the hood up, only one side is released. I have to pull the hood release again to unlatch the other side.
What's causing this?
Old Dec 3, 2008 | 12:43 AM
engle1147's Avatar
engle1147
clean the slide latches attached to the cables and lubricate(latches not the cable) them with silicone spray....hood pins and or rubber hood stops might also be too tight/out of adjustment.
Old Dec 3, 2008 | 01:20 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Loosen the black plastic lock nut and turn the inner long black nut inward to pull the latch back a little; then snug up the lock nut.
Old Dec 3, 2008 | 08:23 AM
runner140*'s Avatar
runner140*
As a safety precaution use a couple of zip ties (18").
[/IMG]
Old Dec 3, 2008 | 09:36 AM
dredd0822's Avatar
dredd0822
Thanks for the tips guys, I'll try them out.
Old Dec 3, 2008 | 01:56 PM
JAKE's Avatar
JAKE
[/IMG]
I agree because without the ties, if the cable breaks, you'll be cussin' and fussin' all the while you're trying to pop the hood with a coat hangar or some other tool.
Jake
Old Dec 3, 2008 | 02:34 PM
NEVRL8T's Avatar
NEVRL8T
Jake
I don't totally agree. Zip ties get brittle over time from the heat under the hood and break easily after a while. Use steel cable instead. This is what I did to my car. These pics aren't good but you get the idea:
To Hood Latch Release problem
