91 L98 Driving me crazy Help
91 L98 6 speed, mild cam, forged pistons, custom chip, and ported. Serpentine belt broke ran hot 260 for a minute or so. After replacing belt there was a miss in the engine and acceleration retarded and backfiring through the exhaust when down shifting. Found 3 bad plugs. Installed 8 new plugs FR5LS .gap 035, ran perfect for about 20 minutes. Thought problem was solved but after starting the next day it ran perfect for about 10 minute turned it off after restarting the miss and retard as mentioned above showed up. Rechecked plugs they were OK. Head gasket OK. Next day drove the car hard for 90 minutes ran perfect. Again thought it OK. The next day ran great for 5 minutes stop for fuel after restarting rough idle, missing and retard, and backfiring showed back up.
Any help greatly appreciated.
nysec
nysec
Rechecked plugs and wires found one wire not connected properly to the plug. reconnected but no change. Did resistance test on injectors (cold) #6 @2.5, #2 @8.50 others around 16.50.
Should I just replace all the injectors see if that corrects the problem before looking for other causes?
That would coause your problem allright
There is a supporting member here that I haven't used (I'm not the injector type) but there have been many good comments about their expertise and advise.
FIC injectors I believe
A search should do the trick and you can PM them
Thanks for all the help. Jon at FIC was the first I called and he had the Bosch injectors ready to ship so I should have them today or tomorrow.
Will keep you posted on how it goes, again thanks for the help.
nysec
nysec
A big thank you to forum members for your help.
New Bosch III injectors installed. Problem solved, car never ran better.
It was a pleasure to deal with Jon at Fuel Injector Connection. He was very helpful and the service was great. I want hesitate to recommend him to anyone.
