looking for headers for my 1986 help
Old Dec 6, 2008 | 01:47 AM
burmeister's Avatar
burmeister
Default looking for headers for my 1986 help
can anyone tell me what is a good header to put on my c4 1986.. and price. thanks rob
Old Dec 6, 2008 | 09:56 AM
c4cruiser's Avatar
c4cruiser
Hooker Competition Plus headers are good but very pricey. Around $550 or so.
Hedman makes good headers with and without the AIR and EGR connections. Summit Racing has them. Make sure you get the version with the thermal coating. These will run in the $350 range.
You will also have to figure on another $200 to $300 for the rest of the exhaust hook-up, and other mufflers if you want them.
Full length headers like these will install with no real problems but once the passenger side header is in place, there is no way to remove the factory starter without removing the header. Most people will install a smaller gear reduction starter as those can be removed without header removal.
Headers will require the removal of the pre-cats but you can still run a Y-pipe and the main cat if you have to do emissions testings. I can't remember if these headers come with an installed O2 sensor bung, but one will have to be installed if they don't come that way. It's easier to get a heated O2 sensor and install it at the driver's side collector. There will be 2 wires; one for 12v and the other for the existing O2 sensor wire. That fools the ECM so that it goes into closed loop mode for economy/emissions.
Old Dec 6, 2008 | 10:20 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I installed Hedman Elites and they were easy to tie into the stock "Y".
Old Dec 6, 2008 | 12:28 PM
slickfx3's Avatar
slickfx3
http://www.bassani.com/part/57421C4C
Old Dec 6, 2008 | 03:25 PM
856SPEED's Avatar
856SPEED
I have TPIS (Tuned Port Injection Specialists) on mine; look them up on the web; also Exotic Muscle as I have heard here on the forum have a great set....do a search on the forum here as this topic gets covered pretty well...you'll get plenty of opinions and info..
Old Dec 7, 2008 | 03:26 AM
burmeister's Avatar
burmeister
you guys all have been a huge help. thanks alot guys...rob
Old Dec 7, 2008 | 10:52 AM
BornIn87's Avatar
BornIn87
i have recently put hooker super comp on mine.1-3/4" x 26" Primary Tubes. 3" Collector
Old Dec 7, 2008 | 11:11 AM
Radioshop's Avatar
Radioshop
I would add, go with the one that has the thickest plate where it bolts to the head. The last Corvette headers I dealt with were long tubes and they were from Hedman because of the plate thickness. After 10,000 miles, no gasket spitting.
Old Dec 7, 2008 | 01:32 PM
856SPEED's Avatar
856SPEED
I agree; you should look for thick flanges as they are called and I would opt for the ceramic coated if your budget allows to keep the underhood temperatures lower and better exhaust scavenging......
Old Dec 8, 2008 | 05:19 PM
Jared1984's Avatar
Jared1984
I have melrose longtubes on my 90. They are not the cheapest by any means...but fit/finish is phenominal Very high quality piece
http://www.melroseheaders.com/produc...eaders/c-4.php
Not sure if your actually in the market...but saw these hooker longtubes in the C4 parts FS section...take a look...seems like a decent deal http://forums.corvetteforum.com/c4-p...e-headers.html
Old Jan 24, 2009 | 06:22 PM
levimoran79's Avatar
levimoran79
What will happened if you comletely remove the catalytic converters , and install pipes instead???
Performance wize and sound wize how loud and how strong it is going to be?????? I dont care about the inspection issue, for now! I am going to install HHO system on it and that will drop the emission!
Old Jan 25, 2009 | 12:14 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Loud. Consider using bullet cats at a minimum.... quieter/cleaner. Still plenty loud too.
Old Jan 25, 2009 | 01:40 AM
c4_4ya's Avatar
c4_4ya
I put the Hooker LT's on my 85- smog legal ones. Install wasn't too bad, nice fit and made a bit of difference. Got mine from a forum member for $300 I think used. BTW, I still have my factory starter (the mammoth one) and can still, just barely, get it in and out of the very tight squeeze.
Old Jan 25, 2009 | 01:57 PM
LT1*C4's Avatar
LT1*C4
Long tube headers made by Exotic Muscle are a very popular choice among C4 owners. A bit more pricey than the hookers but they come highly recommended by those who run them on their cars. Ease of installation, excellent ceramic coating and superb fit and finish are some of the more common trademarks of EM's headers. EM's customer service also appears to be top-notch as well.
I can't comment on the Hookers, Hedman or TPIS's offerings, since I've never run any of them of my previous vehicles, but if you decide to go with any of those, I'm sure you'll be more than happy with them too.
Just for your information though, EM is currently having a group purchase sale on their longtubes and are knocking $100 off their usual price. They're only producing 10 sets, so it's first come first serve. As far as I know, there are 8 spots left. Price is now $671 until all ten sets are sold off than the price jumps back up to $771. You may want to check out the G.P. thread located here:
http://forums.corvetteforum.com/c4-t...ic-muscle.html
Old Feb 1, 2009 | 04:15 PM
burmeister's Avatar
burmeister
thanks guys. listen i took off all the smog stuff and now i need a bracket for the altanator and i will have to size up for a new belt.. but as for headers im looking at the hedman.. any special one i should look at? i want to make the fit as easy as possible. i am not a mechanic. thanks robert
Old Feb 1, 2009 | 04:40 PM
tjwong's Avatar
tjwong
Melrose makes an excellent set of headers for the LTx and L98 cars, the best thing for the L98 cars is that they build a true dual system for them that resembles much of a LTx car without the resonator. It is made so that virtually any aftermarket LTx rear kit will bolt right onto their system which ends at the rear of the car. And its made in the USA and its all SS with the exception of the headers which are coated inside and out.
Old Feb 1, 2009 | 04:41 PM
Aardwolf's Avatar
Aardwolf
Making an alt spacer is real easy, just use a bushing or some tubing. Heck a long bolt with several nuts on it would even work. The stock brace worked on mine. Make sure to check the passenger side for clearence, I had to move the fuel lines and saw off part of the frame brace.
Pic for reference.
Old Feb 2, 2009 | 09:43 AM
AGENT 86's Avatar
AGENT 86
If you removed the A.I.R. pump, a different size belt is not going to work. Your going to need a bracket/pulley to replace the A.I.R. pump, so everything still turns in the correct rotation.
There are aftermarket bracket/pulleys available to due just that. I built my own, but the pic will give you an idea on what's required.
If you going to go with Hedman, get the Elites with no smog stuff and weld in an O2 bung into collector adapter. Decent header for the price.
To looking for headers for my 1986 help
