Hesitation under WOT
With less than 1/2 a tank, it stutters really bad under wot or near wot. As in, snap your head forward, complete loss of power, etc. Not sure why, feels almost like it is out of gas, but as soon as it slows it picks back up again, it will continue to surge and drop until you let off the gas. I want to say fuel pickup is located badly, but I dont know. I would think fuel filter or pump, possibly low voltage on the pump, I know quite a few GM vehicles had problems with wiring for the fuel pump. Also as a note, i put 16 gallons in it when it showed about 1/3 of a tank left, so i think the gauge may be off.
I have driven it about 2000 miles, mostly highway, and have never really had a problem with it. Took it to the track this weekend, had a full tank, and experienced a few problems as well. It seemed like it was hitting fuel cutoff about 5500 revs, well short of 6k, and felt a bit anemic up top. I think its a fuel problem, but I have seen people on here post about cleaning throttle bodies and changing spark plug wires and fixing similar hesitations.
Any ideas? I have searched on here and cannot really come up with an answer.
There's a fair amount of tank pressure released when I open the filler, so bumping the pressure a bit makes sense.
on another note, I had similar symptoms that ended up being the opti.
good luck
The reason I think it is fuel is because the only way to get the hitching problem is at a 1/2 tank or lower, but it could be something else.
Thanks for the input
