Intermitent kocking
Old Dec 12, 2008 | 10:48 AM
Heidi's Avatar
Heidi
7th Gear
Default Intermitent kocking
I have a 1996 Silver Edition Corvette, LT4 automatic with 90,000 miles. I have the car regularly serviced and is in excellent condition. Yesterday, when I started the car I heard an intermittent clicking/low knocking sound. There is no grinding when I start the car and all fluid levels are where they should be. It is more persistent on lower RPMs and when the car idles and gets muffled on higher RPS. There is no spark misfire. It sounds like perhaps a bearing problem??? I initially thought it may be the catalytic converter. The rocker arms/pistons look fine when I removed the head covers. The computer module in the car shows no malfunctions. Without tearing down the engine I am looking for any suggestions. It has been difficult trouble shooting this problem and any suggestions would be appreciated!! Thank you!!
Old Dec 12, 2008 | 10:12 PM
engle1147's Avatar
engle1147
My 2 cents:
Change the serpentine belt.....yes -- I know it sounds silly....the belt may have streched too far and the tensioner is tapping on itself at low RPMs and creates a knocking noise....as engine RPM increase the belt deflects and makes the tensioner move towards a more loaded postion away from the tensioner's stop so the noise goes away.
Old Dec 12, 2008 | 10:13 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
I was gonna fix the title, but it's more fun this way
Old Dec 12, 2008 | 10:28 PM
engle1147's Avatar
engle1147
Old Dec 13, 2008 | 10:46 AM
Keystring's Avatar
Keystring
Old Dec 13, 2008 | 11:21 AM
l98tpi's Avatar
l98tpi
Max G’s
Originally Posted by engle1147
My 2 cents:
This is true, it could possibly be your idler pulley itself. Other items could be a lifter or even worse a wrist pin.
To Intermitent kocking
