Weird Misfire Problem.. Please Help
Old Jan 17, 2002 | 06:24 PM
N20LT4's Avatar
N20LT4
Default Weird Misfire Problem.. Please Help
My car has developed a strange problem. When it is cold i can start driving it and if i am just going through the gears slowly, i can let the RPM's start going up from 2000 and between 2000 and 3000 it start sputtering and misfiring real bad. Now if i give it more gas it will go away. By more gas i mean at least 3/4 throttle. It only does this when it is cold, never after it warms up. Any suggestions? Thanx guys.
Old Jan 17, 2002 | 07:35 PM
jfb's Avatar
jfb
Default Re: Weird Misfire Problem.. Please Help (N20LT4)
How many miles do you have on your spark plugs? Have you pulled a couple and looked at their condition? What is your initial timing? Check all of your spark plug wires with an ohmeter, they should be close to 5000 ohms per foot. Start your car on a dark night and look for sparks along the plug wires indicating bad insulation.
Old Jan 17, 2002 | 07:43 PM
lspalding's Avatar
lspalding
My son's rice burner had this same problem. We changed the plugs and wires and it went away.
OK, it's a turbo eclipse, not a bad ride. :yesnod:
Old Jan 17, 2002 | 09:44 PM
89 Bob L's Avatar
89 Bob L
Definitely sounds like new wires are in order
Old Jan 17, 2002 | 10:03 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: Weird Misfire Problem.. Please Help (89 Bob L)
Sounds like its tune up time, nothing more......Thats generally what it ends up being. Something simple.
To Weird Misfire Problem.. Please Help
