DOS in full screen?
Old Jan 18, 2002 | 10:56 PM
Allblownup's Avatar
Allblownup
Default DOS in full screen?
I cannot get my program to run in full screen. I have changed all properties and still cannot get it to run right. I do not think my display settings will allow. What can I do any help would be appreciated? :seeya
Old Jan 19, 2002 | 12:26 AM
scorp508's Avatar
scorp508
Default Re: DOS in full screen? (Allblownup)
:confused:
Are you running DOS programs through a commandline from another OS? Or are you booting staright to DOS and it won't load the entire screen?
Old Jan 19, 2002 | 06:41 AM
dmalhi1's Avatar
dmalhi1
if yer running that dos window through like well the windows os then just hit alt + enter and it should go to full screen and then hit it again and it goes back to regular.
Old Jan 19, 2002 | 12:21 PM
Allblownup's Avatar
Allblownup
The I had already tried alt+enter and that will not work. I have also started from command prompt and that will not work.Anymore ideas? thanks :seeya
Old Jan 19, 2002 | 11:40 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Have you considered making a short-cut and then change the properties to full screen?
Old Jan 20, 2002 | 11:26 AM
Allblownup's Avatar
Allblownup
I have tried that also. Set to maximize and to full screen. More help please. I am also trying to find better display drivers to see if that will help and that did not work. Thanks :seeya
Old Jan 21, 2002 | 01:34 AM
HighHopes85's Avatar
HighHopes85
When you turn on the 'puter, hit and hold down control or F8 to get to your startup mode where it asks you to boot up normal, safe mode, command prompt, etc. Just run it straight from the DOS without ever going into windows in the first place. This does double duty in preventing any drivers being loaded for the port that Diacom uses. -Matt-
Old Jan 21, 2002 | 11:31 PM
Allblownup's Avatar
Allblownup
I will give that a try once I straighten out my computer. I was trying to load some driver and cannot get to work right. I am not using Diacom. I am using Haltech DFI system and it runs fine on my other laptop. Thanks :seeya
To DOS in full screen?
