turn signals
Old Jan 9, 2009 | 01:38 PM
J_z52's Avatar
J_z52
5th Gear
Default turn signals
okay first off my right turn signal wont flash and when the lights are on the turn signal stays on in side. yet when i put the emergancy lights on it will flash inside and back lights but not my turn signal to the right in the front wont even be on. sorry guys just bought this 86 corvette nd the price was a steal like you wont even believe. help please
Old Jan 9, 2009 | 01:57 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
front bulb turn signal filament is burnt out and maybe the filament fell across to the other filament to confuse things.
Old Jan 9, 2009 | 02:11 PM
engle1147's Avatar
engle1147
Old Jan 9, 2009 | 03:47 PM
J_z52's Avatar
J_z52
5th Gear
its a new bulb
Old Jan 10, 2009 | 02:04 PM
rons85's Avatar
rons85
Then you have a wiring issue at that corner. Possibly the bulb socket is bad. Possibly someone has "fixed" something there before and that fix is now going bad. Something is going on there..
It is Remotely possible that the turn signal switch itself is causing this, but by the way you describe the symptoms it's pretty unlikely. Get a test light out and look for voltage (and ground) at the bulb socket there with the signals on, and with the Flashers on. With and without the Parking lights on. I'll bet you have NO flasher voltage getting there and that you have a bad wire or wiring harness connector someplace in the circuit. Assuming the bulb Socket is OK.
Old Jan 10, 2009 | 03:30 PM
engle1147's Avatar
engle1147
its a new bulb
I've had "new" bulbs be bad too. I'm guessing you changed the "old" bulb to try to fix the origional problem.....was the "old" bulb burnt out? Clean the goop out ot the socket then check the socket as the CF member suggests......other CF members have had the socket wires back out also.
Old Jan 10, 2009 | 07:29 PM
mgafun's Avatar
mgafun
Anette sells good bulbs.
Old Jan 11, 2009 | 12:47 AM
jfb's Avatar
jfb
The turn signal and emergency flasher use separate flashers. The flashers work on current, low current, slow or no flashing rate. High current, rapid flashing. Your right turn signal won't flash because the right front turn signal lamp filament is not getting current. Check the lamp with an ohmeter, if ok, then look at the condition of the socket. GM puts lithium (white) grease in the sockets to keep water out and lithium grease gets hard when it gets old and prevents the socket from making electrical contact with the lamp. 1986 grease is definitely hard now! Clean the socket out with a Q tip and either alcohol or electrical contact spray. Check the wires going to the socket for a broken wire.
Old Jan 11, 2009 | 11:05 PM
J_z52's Avatar
J_z52
5th Gear
Default got it
Thanks for everybodys help, i found the problem. It turns out that someone did fix it before and had switched the wiring, connected the right ones together now works like a champ. this is just one of the many problems that i have. on to the next item.
To turn signals
