Hedman Hedders question
Old Jan 10, 2009 | 03:59 PM
mrdahk's Avatar
mrdahk
Default Hedman Hedders question
I saw these headers mentioned in another thread that I cant find now. http://www.jegs.com/i/Hedman/500/68440/10002/-1
What all do I need along with that to install on a 1986?
"Modification to stock exhaust required to retain catalytic converter."
"Must modify rotary A/C bracket"
How much modification is really required?
Old Jan 10, 2009 | 07:31 PM
mrdahk's Avatar
mrdahk
/bump because I need to order them soon if they're going to work.
Old Jan 11, 2009 | 12:09 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
You will need to buy/make a spacer for the support for the of the A/C bracket on the pass side, and the Alt on the drivers side. Do a search on it, I am sure you'll find what you need.
Randy
Old Jan 11, 2009 | 07:56 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It's been 2 years and I still have not made my brackets , but I will this winter.
Once the pre-cats are cut off, it's just a matter of welding the collector adapters onto the the Y.
Here's a pic of mine before I welded the adapters on.
To Hedman Hedders question
