85 Coupe HELP
TBH, im getting tired of throwing money at it lol im only 17 and i work at a grocery store so i dont have a lot of money to throw around.
How is the idle? Is it smooth or does it have a stumble?
I assume the car is down on power from your description. The lack of power and the hard start could mean bad fuel injectors. Luckily, you have an early C4 and they used the Bosch injectors which can be serviced/rebuilt and returned to new condition cheaply. www.cruzinperformance did the ones in my 86' and I have been happy with the work. but before you spend any money on repairs, you should do everything you can to determine the problem/problems.
You will want to check the ohmage of the injectors, and see if you can check the fuel pressure as well. If the injectors are leaking, fuel pressure will drop off faster than it should once you turn the car off.
You said the timing has been set, have you had a chance to look at the harmonic balancer? The balancer can slip and that will throw off the location of the timing notch and even though the car will show it is set for 6 degrees, in reality it is not. I have a pics of a bad balancer if you are interested.
You could have bad sensors (O2, MAP, IAT, etc) as well.
Where are you located (roughly)? Perhaps there is a forum member who can offer an up close opinion/inspection.
The stuff you did already to the car is money well spent...good maintenance. Get a hold of a fuel pressure gage and do some pressure checks at the fuel rail before you throw any more money/parts at it. Also check the car for stored engine trouble codes.....for the sensor related issues mentioned above. Other component that may be relevant to your situation and would cause a lot of the same issues you described is clogged cat/s.
Bob
Bob
You might also check with the previous owner to find out if a modified chip was installed. They can cause problems as well.
Good luck. You'll find that some of the forum members will badmouth the early C4's, but I have found the 85 to be a good year for do-it-yourself owners. Just have the patience to research the problems you encounter and ask for help when needed.
I live in Central Wis. and the car has collector plates, so i cannot drive it in January. I store the car in my garage from late nov to april (or whenever the f***'in snow melts)
Fuel pressure should be 33-34 at idle and 39 with throttle. Sounds like your pressure is OK. I suspect your fuel pump is fine for now. They tend to either work or not. I found that out 150 miles from home.
Check to see how quickly the pressure drops off when you shut off the engine. If the pressure drops off quickly it can mean you have a leaky injector or a bad regulator. There's a simple test to check the fuel pressure regulator and injectors. There should be plenty of threads describing it. Do not try to rebuild the injectors you have. The original injectors were garbage. FIC can set you up with Bosche III 24 lb injectors that flow better than the originals. You'll find lots of threads about FIC injectors and some videos. First do some testing to verify the injectors are bad.
http://fuelinjectorconnection.com/sh...ad#read_review
those must be the injectors you're talking about.
Any HP gains?
I have a multimeter with a 1k setting and a 10 setting for ohm. Which one do I use and what should the injectors test at? Or what SHOULD thet be?
Another thing with Jon... he is honest and knows his stuff. And his prices are the best. Period.
I would also suggest changing the cats on the car. Get rid of the pre-cats and get you a good main cat. There are kits out there that will bolt right up and eliminate the pre-cats or you can have shop cut them out. Your choice. But open up the exhaust and you will feel a difference.
And move somewhere warm so that you can drive that thing!!
It is easy to check the injectors even without being able to drive the car. And since you are stuck until spring, you have time to save money to do the exhaust.
The biggest gains in power and performance I got with mine (90 L98) was with the loss of the pre-cats and a really good high flow cat and a set of Flowmasters. Budgetwise, not to bad on the wallet and alot of bang for the buck.
