Gear Change
Old Jan 18, 2009 | 02:10 PM
KoKane's Avatar
KoKane
Default Gear Change
Hey guys, I have a 95 6-speed. I was thinkin of changing the gears to 4:10s. Does the whole rearend assy. have to be removed with the diff cover? Or is there a way just to remove the housing? Any other tips you know of? Thanks.
Old Jan 18, 2009 | 02:19 PM
engle1147's Avatar
engle1147
You'll want to remove the whole assembly for the swap...trick is to get the car high enough to pull the whole thing out in one piece. Take your time and you'll do fine.
Old Jan 18, 2009 | 09:07 PM
STL94LT1's Avatar
STL94LT1
You can just pull the differential, that's the way the shop did mine. I highly recommend 4.10's for the M6 LTx cars!!
Old Jan 19, 2009 | 07:24 AM
The Bus's Avatar
The Bus
I just pulled and replaced mine. Looks tough but actually a easy job. Use a transmission jack to support the diff assy. I have a diff [ 4.09 : 1 ]with cracked bolt holes where the bolts hold it to the "C" beam. Cheap. The internals are fine. If anyone is interested I can be contacted at orawiecs33@comcast.net
Old Jan 19, 2009 | 05:21 PM
KoKane's Avatar
KoKane
Thanks guys. Glad to hear i can just remove the housing without the diff cover.
Old Jan 19, 2009 | 06:16 PM
El T1's Avatar
El T1
KoKane, is that a DeLorean?
Sincerely, Michael J. Fox
Old Jan 20, 2009 | 05:12 PM
KoKane's Avatar
KoKane
Yes it is. Thats my other hobby.
To Gear Change
