rear ride height
Old Jan 20, 2009 | 09:04 AM
jon0108's Avatar
jon0108
Default rear ride height
My rear right side is about 1 inch higher than the left side. I measured on level ground up to the middle portion of the rear wheel fender lip on both sides.
I just had all new poly bushings installed in the rear and its still the same.
Should I just adjust one of the nuts and bolts on the rear springs to compensate for the difference? Right now both spring bolts are identical
Old Jan 20, 2009 | 09:52 AM
engle1147's Avatar
engle1147
The ride height from L to R is/can be off...this is normal for C4s. Drive the car for a day and run over some small bumps and see if it settles a bit more.
Old Jan 20, 2009 | 10:00 AM
92 6speed C4's Avatar
92 6speed C4
Definitely drive it around after you adjust it, and make small changes each time. Mine was off as well, but it is an easy fix with a little patience.
Old Jan 20, 2009 | 01:14 PM
StealthLT4's Avatar
StealthLT4
Yes, the bolts will almost always be at different positions. I didn't notice what mine was before I lowered it, but the bolts are about 1/2" - 3/4" different in order to achieve even ride height. Just a side effect of the independent suspension.
Old Jan 20, 2009 | 01:59 PM
seijack's Avatar
seijack
How does it measure in the front? Does it also reflect the same measurements.
Old Jan 20, 2009 | 02:02 PM
Nathan Plemons's Avatar
Nathan Plemons
I'd say it's pretty normal. Mine is a lot better since I replaced the bushings with all poly. Even at that though the independent rear moves so much it can be very hard to judge. Even when you think the car is on perfectly flat and level ground you can see difference from one day to the next.
Old Jan 20, 2009 | 03:50 PM
ekess744's Avatar
ekess744
Old Jan 20, 2009 | 06:03 PM
jon0108's Avatar
jon0108
I thought about adjusting the nuts on the bolts, but there is only so much you could adjust them because of the hole in the bolt that you are supposed to put the cotter pin through. I was just going to get new nuts, the ones with the plastic insert in them to prevent them from backing out.
Question now is what size is the nut and bolt setup
Old Jan 20, 2009 | 06:04 PM
Nathan Plemons
How are your suspension bushings? If they're worn really bad you might be going through a lot of trouble to mask a problem rather than fix it.
Old Jan 20, 2009 | 06:06 PM
jon0108's Avatar
jon0108
The rear is much higher. The rear passenger side is 29 inches, rear drivers side is 28 1/4 inches. I just measured again today after driving it for a while.
Old Jan 20, 2009 | 06:07 PM
Nathan Plemons
Another commonly mentioned problem is that if the car is traditionally driven with only a driver and no passenger, the springs could be weaker on the driver side.
Old Jan 20, 2009 | 06:09 PM
jon0108's Avatar
jon0108
there all new, just got done changing over to poly bushings.
To rear ride height
