Coolant leak
Old Jan 19, 2009 | 02:57 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Coolant leak
Every once in a while, I get a leak out of the front right side of the car. It is right under the radiator, I replaced the radiator when it went and I still have the leak. Funny thing is it only leaks now and again, there does not seem to be a rime or reason, except it only happens when the car is up to temp. And if I have been driving awhile it will leak when I turn the car off and sometimes under hard acceleration.
Any help would be appreciated.
Old Jan 19, 2009 | 03:45 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
cracked radiator, lower radiator hose
Old Jan 20, 2009 | 11:26 AM
pcolt94's Avatar
pcolt94
Check around the overflow plastic tank, hoses cracks etc. Try running a little water from a hose or bottle around the tank and see if it makes its way to the radiator area. If it does not you can then eliminate it and concentrate on the radiator and hose area. Make sure drain plug is closed tight and is seated properly.
Old Jan 20, 2009 | 01:39 PM
rickneworleansla's Avatar
rickneworleansla
The last time I had an intermittent leak it was coming from the end of one of the hoses. It was barely noticeable and only did it when heated up.
Old Jan 20, 2009 | 01:43 PM
Nathan Plemons's Avatar
Nathan Plemons
Although I can't tell you where your leak is coming from, it makes sense if you think about it. Your coolant system is pressurized. If you drive it one mile down the street it won't get terribly hot and it won't get up to operating temperature and pressure. When you do get it up to temp and pressure, then it leaks.
My dad has a 1946 chevrolet pickup truck that leaks like a sieve if you put a pressure cap on it. If you put a non pressure cap on it, it never leaks a drop. Some cars will actually overheat if the wrong cap is installed or if it's not installed tightly so it can pressurize.
BTW the primary reason for the pressurized system is that it can run at a much higher temperature before it boils.
Old Jan 20, 2009 | 02:02 PM
runner140*'s Avatar
runner140*
You might want to use a "radiator pressure tester". It hooks on to where the radiator cap goes and pumps up the system, forcing out coolant where it can come out of.
Old Jan 20, 2009 | 02:03 PM
Nathan Plemons
You can also get a UV reactive dye that you put in the coolant. Drive it around for a while, let it start leaking, and then let it get dark and turn on the blacklight. It'll lead you right back to the leak.
Old Jan 20, 2009 | 03:10 PM
rickneworleansla
Thats CSI ****.
http://www.youtube.com/watch?v=b266NeGU15I
Old Jan 21, 2009 | 01:09 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I will check the bottom hose connection again, this is driving me crazy.
Old Jan 21, 2009 | 01:51 PM
cwyates4's Avatar
cwyates4
Which is exactly what I am doing now.
Funny thing too...Randy's description of his leak is identical to mine.
Old Jan 21, 2009 | 02:05 PM
joecarter85's Avatar
joecarter85
Originally Posted by rickreeves1
OMG !!! <*CoffeeSpewAllOverKeyboard*>
Hilarious.....
To Coolant leak
