94 LT1 coolent sensor
The analog gauge reading of 200* sounds right on, and this is a single wire temp sensor located on the passenger side of the block, just below and to the right of the #8 cylinder. This temp. sensor is ONLY used for the analog gauge and not used by your PCM.
code 15 - Coolant temperature sensor signal indicates a temperature colder than -56 F.
Did you say you tried 3 different temp sensors, and you always get 142* ? (you used the word "switch")
-check the integrity of the connector to the temp. sensor
-I would check continuity from your temp. sensor connector back to PCM ( 2 wire connector, both go back to PCM))
-with key in "on" position, but not runnig, the non-black lead wire should read +5v, which is reference voltage supplied
from the PCM to the temp sensor. The other wire(black) is a digital PCM ground (not chassis ground).
When engine cold, your dig. should be reading approx. outside ambient temperature (but usually reads higher). If you have tried 3 temp. sensors, and all read 142*, I would suspect a problem with
1) connector
2) bad contact at PCM connector (inspect and re-seat)
3) open or short somewhere between connector and PCM
4) I would suspect a bad PCM as last resort.
1) connector
If so, I would suspect a problem with one or more ground points (e.g. driver side bell housing).
Otherwise, suspect a wire or connector problem to the temp sender or PCM. Suggest with key on (but engine not running) try moving the wire/harness around and see if the digital temp changes.
with joecarter85...right on.
