won't start...ugh!
Old Jan 24, 2009 | 08:18 PM
ELVIS' C4's Avatar
ELVIS' C4
From: Sugar Land, TX (suburban Houston area) U.S.A.
St. Jude Donor '09, '13
Default won't start...ugh!
Hi all:
Just changed the oil level sensor on my 92'. New battery in it 1 week old. Backed it in the garage when all done (had it on ramps in driveway)...didn't back it in all the way I realized when I got out. Got back in & went to start it up to move it 6" & nothing? Full power, all lights, nothing dims when I go to crank it, complete silence? Took it in/out of gear (auto), foot on brake, etc. Nothing?
After working on it for a few hours it is dark & I'm tired...anyone have something "obvious" I should look for in the morning???
Thanks in advance for the help!
JK
Old Jan 24, 2009 | 08:20 PM
engle1147's Avatar
engle1147
Try to start it in "N" (neutral)...see if she kicks.
Old Jan 24, 2009 | 08:22 PM
ELVIS' C4's Avatar
ELVIS' C4
Unfortunately...nothing happens in neutral either (just went out & tried again when I saw your post)
any other ideas?
thanks
Old Jan 24, 2009 | 08:24 PM
engle1147's Avatar
engle1147
Did you do anything else to the car?
Old Jan 24, 2009 | 08:25 PM
ELVIS' C4's Avatar
ELVIS' C4
allright, i had a complete write-up on how the factory security system works on 92' & I can't locate it...with the key turned trying to start the "SECURITY" light stays solid & when door closed or key not in turned to engage starter it blinks...possible I am an idiot & this is security system related???
Old Jan 24, 2009 | 08:27 PM
engle1147's Avatar
engle1147
Yep, the VATS is activated if it is on solid. Rearm the car and let it sit for 15-20 minutes and try again after the timer resets.
Old Jan 26, 2009 | 11:11 PM
ELVIS' C4's Avatar
ELVIS' C4
I was an idiot...she fired right up after I rearmed & she fired up.
Thanks again!
This is a fantastic forum...can't become a lifetime member right now but I can become a supporting member which I hope all do in order to keep this bad boy up & running & helping all!
Old Jan 27, 2009 | 08:24 AM
engle1147's Avatar
engle1147
Thanks again!
To won't start...ugh!
