I have an 89,auto,with 81000miles. My problem started about a month ago. When I applied the brakes they worked fine but when you coutiuned to hold pressure the peddle would slowly go to the floor. My local NAPA said it was either the Master Cylinder or Power Booster I replaced both at the same time. The master cylinder was bad from the dealer.I had it replaced but now I cannot get the rear brakes to work. I bench bleed the master cylinder and the front brakes are working. The rear brakes are getting fluid but will not engage. I'm open to any suggestions. Thanks for your help
]I have an 89,auto,with 81000miles. My problem started about a month ago. When I applied the brakes they worked fine but when you coutiuned to hold pressure the peddle would slowly go to the floor. My local NAPA said it was either the Master Cylinder or Power Booster I replaced both at the same time. The master cylinder was bad from the dealer.I had it replaced but now I cannot get the rear brakes to work. I bench bleed the master cylinder and the front brakes are working. The rear brakes are getting fluid but will not engage. I'm open to any suggestions. Thanks for your help.
Sounds like you have some air in the lines from the MC swap. You'll want to bleed all four brakes....there is specific order in which you should perform the bleeding I believe it is RR, RF, LR, & LF....do a search to confirm the sequence I've given you is correct.
The Rule-of-Thumb is to start with the furthest caliper from the master cylinder then work successively in. For most cars that would be RR, then LR, RF, then LF. BUT on '86 and later Corvettes we have the ABS unit behind the driver. So IIRC RF, LF, RR, LR.
I did not install any bias spring. I called myself bleeding the brakes but I guess I quit too soon. Will take yhour advise and redo ii from the start. including the master cylinder forward. Thanks for the advise.
The real issue is the air in the system ....
Really? This is the first time I've heard this. Can anyone comment on the correct order? I did the normal RR, LR, RF, LF last time I changed my fluid, and I'm not 100% sold on the fact that all the air is out...
Hes right. The brake lines and ebtcm are behind driver seat.
\rotated air in tires, no help,haha. I've always blead them starting with the fartherest to the closest. Will follow the FSM just to be sure. Thanks for all the good advise.
