zz4 engine question?
Old Mar 25, 2009 | 12:13 AM
rodj's Avatar
rodj
Originally Posted by mavidatt
also what would be the best rocker arm to get?
Define BEST?
Value for $ , quality , endurance?
Old Mar 25, 2009 | 01:37 PM
bill mcdonald's Avatar
bill mcdonald
as far as the zz4 oil pan vs L98.
Does the ZZ4 have the main bolts with the extended threads to use the L98 sheet metal oil baffle, or does the zz4 have a different one, or not use one all together?
Is there any reason you cant use the l98 baffle and oil pan on the zz4?
Old Mar 25, 2009 | 05:52 PM
SuperL98's Avatar
SuperL98
The ZZ4 parts list shows the Windage Tray number #12554816
http://www.crateenginedepot.com/pdfs/SB_zzengine.pdf
SDPC lists that as the corvette baffle
http://www.sdpc2000.com/product/1255...ndageTray.aspx
So I think the answer is they are the same, but (for the reasons I stated above) I didn't take my pan off to see, first hand.
I don't see any reason the Corvette pan & pickup tube would work, but I just haven't done it myself, to tell you :o
Old Mar 25, 2009 | 05:57 PM
SuperL98's Avatar
SuperL98
I'm sorry that should read "No reason why it WOULDN'T work".......
Can't seam to get back in to edit it..
Old Mar 25, 2009 | 07:10 PM
mavidatt's Avatar
mavidatt
Originally Posted by rodj
Define BEST?
good quality that is not to expensive
http://www.jegs.com/i/Patriot+Perfor...3831S/10002/-1
oh yeah does anybody know much about this engine sb chevy 383 from patriot performance? It is pretty good price, but is it good quality? i would use my own intake on it though, edlebrock intake base and runners with my tpi if it is good.
