[update - pic] Engine....
Old Jan 23, 2002 | 06:33 PM
  #41
RichS's Avatar
RichS
Default Re: [update - pic] Engine.... (Glock'94)
Are those the Stock LT4 rockers that are non-adjustable. If they are they have no set screw in them. They just get torqued.
Old Jan 23, 2002 | 08:11 PM
  #42
GlockLT4's Avatar
GlockLT4
Default Re: [update - pic] Engine.... (RichS)
Hmm.. you sure? Yes, they are the factor LT4 ones ... look in the pictures. They have the chevy bow tie.
What torque are they supposed to be set down to?
[Modified by Glock'94, 6:12 PM 1/23/2002]
Old Jan 23, 2002 | 10:51 PM
  #43
RUDY S's Avatar
RUDY S
:cheers: :chevy :cheers:
Old Jan 23, 2002 | 11:16 PM
  #44
95BLKVette's Avatar
95BLKVette
Default Re: [update - pic] Engine.... (RUDY S)
Hey Glock,
This is what I did to my heads with the Standard Abrasives Head Porting/Polishing Kit when I had about 50 hours free while I waited for my block to get No.2 sleeved and all cylinders alignment bored .030 over on my 383 stroker rebuild :rolleyes:
[Modified by 95BLKVette, 9:23 PM 1/23/2002]
Old Jan 24, 2002 | 12:12 AM
  #45
GlockLT4's Avatar
GlockLT4
Default Re: [update - pic] Engine.... (95BLKVette)
Cool pics!! Once I buy new tires, and have $ saved up for the tranny, and a couple other things, I will buy a set of LT1 heads from e-bay for like $300 and do a nice port job to them.
Old Jan 24, 2002 | 12:13 AM
  #46
GlockLT4's Avatar
GlockLT4
You were right!! Called my builder and he said after looking closely and talking to a couple people, the locks aren't needed on them... thanks!
Old Jan 24, 2002 | 08:20 AM
  #47
RichS's Avatar
RichS
Not sure of the torque is of the nuts. I can check the manuals later.
Old Jan 24, 2002 | 07:55 PM
  #48
NoWorries's Avatar
NoWorries
I don't know if there is a set torque, although there very well may be. For hydraulic lifters though, I believe the accepted method is to tighten until you can no longer spin the push-rod freely(with the oil system primed and the lifters filled), then 1/2 a turn. Its what I did and approaching 1300 miles now and still no noise. Good luck!
Old Jan 24, 2002 | 08:52 PM
  #49
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: [update - pic] Engine..... (Glock'94)
Heh...what if your builder accidentally got EM gaskets for an L88, for an LT-1 C3? :D
Old Jan 24, 2002 | 08:54 PM
  #50
GlockLT4's Avatar
GlockLT4
Default Re: [update - pic] Engine..... (Matt Black)
That would suck. It's already put together and running, so I hope not!
Actually I saw the boxes for the gaskets.. they were for an LT1, definitely (not the older one)
Old Jan 24, 2002 | 09:00 PM
  #51
h rocks's Avatar
h rocks
Default Re: [update - pic] Engine.... (NoWorries)
:confused: :confused:
